MDX - Intrinsic Members
Posted: Fri May 27, 2022 5:22 pm
by gtonkin
Intrinsic members are basically built-in properties that can be used in MDX for selection and filtering.
The below table lists a few of these with some examples based on the SData samples.
Types are Context Sensitive (CS) or Non Context Sensitive (NCS) - See this article for an explanation.
PropertyTypeExampleNotes
ELEMENT_INDEXNCSFILTER(
{TM1SUBSETALL( [model] )},
StrToValue([model].CurrentMember.Properties("ELEMENT_INDEX"))<=10)
Filtering based on the element index per the properties window in the subset editor
ELEMENT_LEVELNCSFILTER(
[model].CurrentMember.Properties("ELEMENT_LEVEL")="0")
Based on Level 0 being N-Level or Leaf and counting up as you ascend the hierarchy.
ELEMENT_TYPECSFILTER(TM1SubsetAll([account1]),
[account1].currentmember.properties("ELEMENT_TYPE")="2")
Will find all String Type elements in the dimension. 1=N, 2=S, 3=C
MEMBER_CAPTIONCSFILTER(
INSTR(1, [model].CurrentMember.PROPERTIES("MEMBER_CAPTION"), "Sedan", 1)>0)
Does not appear to be looking for the Caption attribute/alias
MEMBER_NAMENCSFILTER
({TM1SUBSETALL( [model] )},
[model].CurrentMember.Properties("MEMBER_NAME")="T Series 2.8 L Sedan")
Appears to be the same as:
FILTER
[model].CurrentMember.Name="T Series 2.8 L Sedan")
MEMBER_ORDINALCSFILTER(
ORDER
StrToValue([model].CurrentMember.Properties("MEMBER_ORDINAL")),BASC),
StrToValue([model].CurrentMember.Properties("MEMBER_ORDINAL"))<=10)
Ordinal appears to be the index number of the member when sorted by Hierarchy. The example returns the first 10 members in the hierarchy (rollup)
MEMBER_WEIGHTCSFILTER(TM1SubsetAll([account1]),
[account1].currentmember.properties("MEMBER_WEIGHT")<>"1.000000")
or
FILTER(TM1DrillDownMember(TM1SubsetAll([test]),ALL,Recursive),
StrToValue([test].currentmember.properties("MEMBER_WEIGHT"))=-1)
Find elements based on their weighting
LEVEL_NUMBERNCSFILTER(
[model].CurrentMember.Properties("LEVEL_NUMBER")="0")
Based on Level 0 being Root and counting up for subsequent levels below Root Members
Same as:
FILTER(
[model].CurrentMember.Level.Ordinal=0)
LEVEL_NAMENCSFILTER(
[model].CurrentMember.Level.Name="Series")
Filter on named levels per the }HierarchyProperties cube
PARENT_LEVELCSFILTER(
[model].CurrentMember.Properties("PARENT_LEVEL")>"0")
Returns all Members without Root entries which would be Parent's with a Level of 0
CHILDREN_CARDINALITYCSFILTER(
[test].currentmember.properties("CHILDREN_CARDINALITY")="0"),
[test].currentmember.properties("ELEMENT_TYPE")="3"))
CHILDREN_CARDINALITY = Number of children for a member
Example returns C Level Members having exactly No Child elements.
Filtering on "0" returns Leaf members or C Level members without any children.
Below will return N and C with no children:
FILTER( {TM1SUBSETALL( [model] )},
Count([model].CurrentMember.Children)=0)
DEFAULT_MEMBERNCS{[Model].DefaultMember}As defined in the }HierarchyProperties cube
ALL_MEMBERNCS{[Model].AllMembers}Seems same as {[Model].Members}
The list below includes some other items that still need to be researched and may be relevant using the REST API for MDX and Cellsets:
MEMBER_UNIQUE_NAME, PARENT_UNIQUE_NAME, DIMENSION_UNIQUE_NAME, LEVEL_UNIQUE_NAME
DIMENSION_CARDINALITY, DIMENSION_NAME, DIMENSION_ORDINAL, DIMENSION_CAPTION, DIMENSION_TYPE
HIERARCHY_CARDINALITY, HIERARCHY_NAME, HIERARCHY_UNIQUE_NAME, HIERARCHY_CAPTION
LEVEL_TYPE, LEVEL_CARDINALITY
IS_PLACEHOLDER, CATALOG_NAME, CUBE_NAME, STRUCTURE
TM1UPDATEABLE, , UPDATEABLE, READONLY_STATUS, TM1RULEDERIVED, ANNOTATED, CONSOLIDATED,
LAST_SCHEMA_UPDATE, LAST_DATA_UPDATE, CELL_ORDINAL
FORMATTED_VALUE, FORMAT_STRING, TM1FORMAT_STRING
Let me know should there be some functions missed, errors that need correction or better examples if you have them.
Re: MDX - Intrinsic Members
Posted: Mon May 30, 2022 7:41 am
Very useful stuff. Especially ELEMENT_TYPE and MEMBER_WEIGHT.
Can you see any advantage using MEMBER_ORDINAL to sort on versus wrapping a set expression wiuth HIERARCHIZE? Seems to me this would produce the same result.
Posted: Mon May 30, 2022 9:21 am
by gtonkin
lotsaram wrote: Mon May 30, 2022 7:41 am Very useful stuff. Especially ELEMENT_TYPE and MEMBER_WEIGHT.
I would probably go with Hierarchize() being a built in function. Sorting based on a property would be slower, I would guess.
Unfortunately there are not always good use cases for the examples so some like the ordering by MEMBER_ORDINAL may be a bit silly and purely academic.
What may be a bit more practical to play with is to return some of these properties as a calculated member using an MDX view on the element attributes cube e.g.
WITH
MEMBER [}ElementAttributes_Scenario].[}ElementAttributes_Scenario].[Ordinal]
  AS [Scenario].CURRENTMEMBER.PROPERTIES("Member_Ordinal")
MEMBER [}ElementAttributes_Scenario].[}ElementAttributes_Scenario].[Type]
  AS [Scenario].CURRENTMEMBER.PROPERTIES("Element_Type"),
SOLVE_ORDER = 1
SELECT {[}ElementAttributes_Scenario].[}ElementAttributes_Scenario].[Ordinal],[}ElementAttributes_Scenario].[}ElementAttributes_Scenario].[Type]} ON 0,
{[Scenario].MEMBERS} ON 1
FROM [}ElementAttributes_Scenario]
Posted: Wed Jun 01, 2022 4:47 pm
by PavoGa
Good stuff! Some of these I've looked for, especially the MEMBER_ORDINAL.
Posted: Tue Oct 03, 2023 1:42 pm
by PavoGa
Got a question. Can we use "ELEMENT_TYPE" to filter for Aliases?
Posted: Tue Oct 03, 2023 9:43 pm
by Wim Gielis
Good question. After 30 min trying a few things I could not come up with a solution using MDX for subsets.
Posted: Wed Oct 18, 2023 6:54 pm
by lav4you
PavoGa wrote: Tue Oct 03, 2023 1:42 pm Got a question. Can we use "ELEMENT_TYPE" to filter for Aliases?
Can you expand on how would you like to filter?
Posted: Thu Oct 19, 2023 7:16 am
by Wim Gielis
lav4you wrote: Wed Oct 18, 2023 6:54 pm
Probably, which attributes are aliases, which are string attributes, which are numeric.
Something like the DType or ElementType functions.
Posted: Fri Oct 20, 2023 4:51 pm
by lav4you
Wim Gielis wrote: Thu Oct 19, 2023 7:16 am
I found one use case as follows
FILTER(
[DimensionName].MEMBERS , [DimensionName].CURRENTMEMBER.PROPERTIES("AttributeName") = IIF([}ElementAttributes_DimensionName].[AttributeName].PROPERTIES("Element_Type") = "2" , "SearchTerm1" , "SearchTerm2"))
Is this something you were looking for??
Lav
Posted: Fri Oct 20, 2023 5:52 pm
by Wim Gielis
lav4you wrote: Fri Oct 20, 2023 4:51 pm Hi,
FILTER(
Lav
Not sure I follow you. Is this supposed to be a solution for the type of filtering I suggested - thinking that PavoGa also wants to filter like that.
Posted: Tue Oct 24, 2023 1:46 pm
by PavoGa
Use the MDX filter function with ELEMENT_TYPE property to filter for aliases. i.e., is there an ELEMENT_TYPE value for aliases on an }ElementAttribute dimension.
As Wim referred to, we can loop through the dim elements with DTYPE or ELEMENTTYPE to do it, but looking for the elegant MDX solution.
Posted: Tue Oct 24, 2023 1:49 pm
by PavoGa
Posted: Tue Oct 24, 2023 1:53 pm
by PavoGa
FILTER(
Lav
Don't think that would do it. Looking to return a list of alias attributes on a dimension when there is not something that readily identifies alias elements like an "a." prefix or something.
