Monitoring User Logins
- Version: 9.5
- Excel Version: 7
Hi there
We are running Pa2, and I am trying to get a record of user logins.
Transaction logging is set for the }ClientProperties cube, but when I review the transaction log, nothing is there.
Any idea?
Chris
Any idea?
Chris
- OLAP Product: tm1
- Version: 10.2.0 - 10.3.0
Re: Monitoring User Logins
Check }CubeProperties LOGGINING mustbe "YES"
- Version: PAL 2.0.9.18
Did you do a Savedata, in order to get a timestamped text file (in the logging directory) containing the data changes since the last savedata or server restart ?
IBM Champion 2024
IBM Champion 2024
Putting something like this in your tm1slog.properties file will create a separate log file with login activity:
This particular example writes all login activity to a file called lock.log.
log4j.logger.TM1.Login=DEBUG, LOCK
log4j.additivity.TM1.Login=false
log4j.appender.LOCK=org.apache.log4j.SharedMemoryAppender
log4j.appender.LOCK.File=lock.log
log4j.appender.LOCK.MaxFileSize=100 MB
log4j.appender.LOCK.MaxBackupIndex=20
log4j.appender.LOCK.TimeZone=GMT
- Version: 9.5
- Excel Version: 7
Hi there
Logging is set, and we do a SaveData every 5 minutes
Chris
Chris
I'm not sure what you are trying to capture with the }ClientProperties cube. There is no attribute in that cube that is going to show login activity. You are going to have to do that in a log like the example I gave you. You don't have to create a separate file, you can make it write to the server log, but you have to have the
lines in your tm1slogging.properties file.
- Version: 9.5
- Excel Version: 7
Hi Tom
Much appreciated, will give it a bash.
Regarding the }ClientProperties cube, I have seen a few posts where people claim that checking out a transaction log on this cube will give you login information.
Chris
Chris
Maybe it used to work in TM1 but it does not in PA. I am on PA and I double-checked again to make sure. There is nothing written to the transaction log for the }ClientProperties cube when a user logs in. The solution involving the tm1s-log.properties setting is the only sure-fire way to get what you want that I know of.
Almost, and in addition ClientPropertiesSyncInterval must be in tm1s.cfg
It works and works fine. But for anything to be written against <}ClientProperties, userID, STATUS> ClientPropertiesSyncInterval must be set. It has been like this for a loooong time, like since 9.5 or 10.1
But the solution already suggested to write to a separate log file by adding parameters to tm1s-log.properties file is a much better solution.
Hmmm, every 5 minutes. Isn't that window rather short ?
IBM Champion 2024
IBM Champion 2024
- Version: IBM Planning Analytics 2.0
- Excel Version: Professional 2016
I cannot find the location for the tm1slog.properties file? Is it not in the same location as the tm1s config file?
Yes. If it’s not there, you should create it. There are examples in the documentation, for example.
IBM Champion 2024
IBM Champion 2024
It is actually called tm1s-log.properties.
Yes - I cannot find this file either. Will I need to manually create a file and name it ''tm1s-log.properties''.
Thanks everyone, will give it a try now.
Didn't you see my post above ?
IBM Champion 2024
IBM Champion 2024
While we're on the subject of logging, if you put this in your tm1s-log.properties file it will create a separate log called TI.log that will contain all messages you send from a TI:
I use it to record all instances of a TI process running, who ran it, and what parameters they used. Here is an example:
In this example I will get an entry in the TI.log file that looks like this when the process is run:
Having this information in a log is extremely helpful when trying to debug a process or finding out who did something.
log4j.logger.TM1.TILogOutput=DEBUG, Debug_LogOutput
log4j.appender.Debug_LogOutput=org.apache.log4j.SharedMemoryAppender
log4j.additivity.TM1.TILogOutput=false
log4j.appender.Debug_LogOutput.File=TI.log
log4j.appender.Debug_LogOutput.MaxFileSize=100 MB
# ========================== WRITE PARAMS TO LOG ==================================
LOGOUTPUT('INFO', '---------------------------------------------------------------------------------');
LOGOUTPUT('INFO', GETPROCESSNAME());
LOGOUTPUT('INFO', 'Executed by ' | TM1USER());
LOGOUTPUT('INFO', 'pPeriod - ' | pPeriod);
LOGOUTPUT('INFO', 'pSourceVersion - ' | pSourceVersion);
LOGOUTPUT('INFO', 'pTargetVersion - ' | pTargetVersion);
17380 [2032] INFO 2020-02-04 20:23:00.658 TM1.TILogOutput Copy Version
17380 [2032] INFO 2020-02-04 20:23:00.658 TM1.TILogOutput Executed by Planning Analytics/Test User
17380 [2032] INFO 2020-02-04 20:23:00.658 TM1.TILogOutput pPeriod - Jan-2020
17380 [2032] INFO 2020-02-04 20:23:00.658 TM1.TILogOutput pSourceVersion - Actual
17380 [2032] INFO 2020-02-04 20:23:00.658 TM1.TILogOutput pTargetVersion - Forecast
- Version: 9.5
- Excel Version: 7
Hi Tom
Thanks once again for all your help. I have created a tm1s-log.properties file, but now the tm1server.log file has disappeared.
I still want this file to get all info about model startup, when users run TIs etc.
Any idea why?
Below is the contents of my log file.
Many thx!
Chris
Any idea why?
Many thx!
Chris
- qml
- Excel Version: 2007 - 2016
Kamil Arendt
