Creating a }Picklist cube in a TI process
Posted: Wed Aug 29, 2018 7:28 am
I'm trying to create a picklist cube for an existing cube using a Turbo Integrator process.
I'm creating a cube with the correct name (}Picklist_Cube_Name) with the same dimensionality as the original cube with the addition of the }Picklist dimension as the final dimension. I'm then attaching a rule to the picklist cube using the RuleAttach TI function.
The code is a little complex, but a simplified version would look like this (given an existing cube called "Cube001" with 3 dims):
This code creates a valid picklist cube with the rule attached, but unfortunately, the picklist only shows up in the target cube after I re-start the server.
I've tried unloading the cube, and selecting "Create Picklist Cube" in architect, but neither work. I don't think the issue is with the structure of the picklist cube itself, since it does work once the server is re-started.
Has anyone tried this? Is there a trick I can use to refresh the picklists once the picklist cube is created? Any help would be appreciated!
Harvey.
sD1 = "dim1';
sD2 = "dim2';
sD3 = "dim3';
sTargetCubeName = 'Cube001';
sPicklistCubeName = '}Picklist_' | sTargetCubeName;
sPicklistDimensionName = '}Picklist';
## Assume this file exists and contains valid picklist rules!
sPicklistRuleFile = '..\source\Cube001_Picklist.txt';
IF(CubeExists(sPicklistCubeName) = 1);
	CubeDestroy(sPicklistCubeName);
ENDIF;
CubeCreate(sPicklistCubeName, sD1, sD2, sD3, sPicklistDimensionName);
RuleLoadFromFile(sPicklistCubeName, sPicklistRuleFile);
Harvey.
