control cube asciioutput
- OLAP Product: Cognos
- Version: 10.1.1
Good morning sir,I need to export cube }client properties dimension }client properties which has alais }tm1_defsultdispalyvalue(alias) iam needing all the users in tm1.please explain.
- Version: PAL 2.0.9.18
Re: control cube asciioutput
Hello
What code do you already have? A while ... end loop over the }Clients dimension? Use ATTRS to retrieve the value of the attribute.
IBM Champion 2024
IBM Champion 2024
There is really only one thing to say to this and you will find it expressed quite nicely here.Moh wrote:Good morning sir,I need to export cube }client properties dimension }client properties which has alais }tm1_defsultdispalyvalue(alias) iam needing all the users in tm1.please explain.
