With which version of Java is TM1 10.2 web developed?
Learn_TM1
Excel Version: Excel 2010
Post by Learn_TM1 »
IBM document shows that TM1 10.2 web is developed by Java. But it doesn't say which version of Java? Could you please tell me about it? Thanks.
Learn_TM1
jwilkins
Version: 9.5.2+
Re: With which version of Java is TM1 10.2 web developed?
Post by jwilkins »
It looks like they use Java 1.7. Naturally, that's IBM Java 1.7.
Emily Wilkins - Software Engineer
Motio, Inc.
Learn_TM1
Post by Learn_TM1 »
Hi jwilkins,
Thanks for your reply. Unfortunately I didn't finde /jre/ folder in my Cognos TM1 installation. I only find the folder as:
C:\Program Files\ibm\cognos\tm1_64
And I can't run "java -version" command.
Is there some official IBM document to declare what Java version is used to develop TM1 products?
jwilkins
Version: 9.5.2+
Post by jwilkins »
I don't know of any official documentation that explicitly says the Java version. However this article may help you locate the jre folder.
https://www.ibm.com/support/knowledgece ... view=embed
You can then run java.exe in IBM_7.0\bin with the -version flag to get the same printout as my screen shot.
Your path would probably be
C:\Program Files\ibm\cognos\tm1_64\bin\jre\IBM_7.0\bin\java.exe
Motio, Inc.
Learn_TM1
Post by Learn_TM1 »
Hi jwilkins,
Thanks for your tips. I found the folder on the server, where Cognos TM1 installed. And I got the Java Version, which is same as yours.
Learn_TM1
Sophie Kay
OLAP Product: HOLAP
Version: 8.1
Excel Version: 2017
Post by Sophie Kay »
Interesting, I've just tried out to test it the same way you've done, me neither didn't find JRE folder, but in my case running version prompt was successful. That's the very thing I can't understand with Java at all: everything works fine by the book, but when you actually trying to do that, it appears to be way more complicated as it supposed to be for another person for sure. I'm new-new to all this stuff, so I'm getting over this with these java tutorials https://explainjava.com/ because everything here is explained from several prospectives and at least one of them should work in any cases. But nevertheless, now I've determined that it's wrong time for me to get it started with TM1 :lol:
Sophie Kay wrote: Thu Apr 05, 2018 10:39 am Interesting, I've just tried out to test it the same way you've done, me neither didn't find JRE folder, but in my case running version prompt was successful. That's the very thing I can't understand with Java at all: everything works fine by the book, but when you actually trying to do that, it appears to be way more complicated as it supposed to be for another person for sure. I'm new-new to all this stuff, so I'm getting over this with these java tutorials https://explainjava.com/ because everything here is explained from several prospectives and at least one of them should work in any cases. But nevertheless, now I've determined that it's wrong time for me to get it started with TM1 :lol:
Why do you feel it necessary to learn Java to be able to develop and/or use TM1? You're talking about code that happens behind the scenes in TM1. You should never change the Java version that comes with TM1 nor change anything in the Java code. I have been developing in TM1 for years and I don't know squat about Java and I'm doing fine.
moby91
Version: 9.5.1
Excel Version: 2003 2007
Post by moby91 »
You may consider to apply the Interim Fix 24 for TM1 10.2.0.2 or the Interim Fix 12 for TM1 10.2.2.7 to address a vulnerability in the IBM Runtime Environment Java Version 7, see the latest security bulletin
1)
http://www-01.ibm.com/support/docview.w ... wg22015269
Security Bulletin: A vulnerability in IBM Java Runtime affects IBM Cognos TM1
Security Bulletin
Summary
There is a vulnerability in IBM Runtime Environment Java Version 7 used by IBM Cognos TM1.
This issue was disclosed as part of the IBM Java SDK updates in October 2017.
Vulnerability Details
Affected Products and Versions
IBM Cognos TM1 10.2
IBM Cognos TM1 10.2.2
Remediation/Fixes
The recommended solution is to apply the fix for versions listed as soon as practical.
Cognos TM1 10.2.0.2 Interim Fix 24
Link: http://www.ibm.com/support/docview.wss?uid=swg24044711
Cognos TM1 10.2.2.7 Interim Fix 12
Link: http://www.ibm.com/support/docview.wss?uid=swg24044712
2)
http://www-01.ibm.com/support/docview.w ... wg24044712
Downloadable files
Abstract
IBM Cognos TM1 10.2.2.7 Interim Fix 12 (10.2.2.7 Interim Fix 12) provides important corrections for Cognos TM1 10.2.2.0.
Download Description
This IF provides important product corrections to Cognos TM1 10.2.2.0, and should be applied to all installations at your earliest convenience. It includes all previous fix packs for Cognos TM1 10.2.2.
