How to create Alternative Hierarchy in TM1
TM1_Easy
Version: 9.5.2
Post by TM1_Easy »
I want to create an alternative hierarchy in Inventory dimension, this dimension already have two hierarchies and I want to create another hierarchy with different consolidation levels.
Could you please explain me how to create an alternative hierarchy.
Thank you in advance
John
Re: How to create Alternative Hierarchy in TM1
Since you already have 2 hierarchies you can see that every element is able to have multiple parent elements and you just add them either manually or through TI with DimensionElementComponentAdd; you just have to avoid using the same consolidation names in both hierarchies if you want it to have different children.
In TM1 there really is no concept of an "alternate" hierarchy. A hierarchy is nothing more than a tree of parent/child relationships and you can have an unlimited number of those in TM1. How to create parent/child relationships is covered more than adequately in the TM1 documentation.
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
As Tomok suggested ,You might find it in Turbo Integrator guide's chapter 9: Advance Scripting :
http://public.dhe.ibm.com/software/data ... 1_turb.pdf Thanks
TM1_Easy
Version: 9.5.2
Post by TM1_Easy »
Thank you all for your kind replies. Sorry, I forgot to mention that I want to create through TI.
Could you please send me the steps to follow.
Jo
TM1_Easy wrote:Thank you all for your kind replies. Sorry, I forgot to mention that I want to create through TI.
Jo
DimensionElementComponentAdd ( <Dimension Name>, <Parent Name>, <Child Name>, <weighting> );
TM1_Easy
Version: 9.5.2
Post by TM1_Easy »
Thank you Declan R :)
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
In addition to what Declan said,Please go through the Advance scripting of TI guide,It clearly explains all the steps in detail for example below code:
The statements should appear as follows:
Prolog>
#****GENERATED STATEMENTS START****
#****GENERATED STATEMENTS FINISH****
DIMENSIONDESTROY(’unbalanced’);
DIMENSIONCREATE(’unbalanced’);
Metadata>
DIMENSIONELEMENTINSERT(’unbalanced’,’’,G1,’n’);
DIMENSIONELEMENTINSERT(’unbalanced’,’’,TOTAL,’c’);
DIMENSIONELEMENTINSERT(’unbalanced’,’’,NORTH,’c’);
DIMENSIONELEMENTINSERT(’unbalanced’,’’,TK1,’c’);
DIMENSIONELEMENTCOMPONENTADD(’unbalanced’,TOTAL,NORTH,1.000000);
DIMENSIONELEMENTCOMPONENTADD(’unbalanced’,NORTH,TK1,1.000000);
DIMENSIONELEMENTCOMPONENTADD(’unbalanced’,TK1,G1,1.000000);
