NewDateFormatter
NewDateFormatter
Hi all
I found 3 interesting new functions in the Reference Guide 10.2: NewDateFormatter, FormatDate, ParseDate.
Useful stuff!
However, I get wrong results, it seems, or I am interpreting the results the wrong way.
In the Prolog tab, since I'm based in Brussels (Belgium):
i = NewDateFormatter('nl_BE', 'Europe/Brussels', 'serial', 'long', 'datetime');
now_formatted = FormatDate( now, 'HH:mm:ss' );
AsciiOutput('test.txt', now_formatted);
The result is 18:48 for me currently in Belgium it is 16:48 (4:48 PM).
Hence, 2 hours of difference.
if I use:
i = NewDateFormatter('nl_BE', 'Etc/UTC', 'serial', 'long', 'datetime');
I get the correct result but this is not how the function should be used, is it?
See http://en.wikipedia.org/wiki/List_of_tz ... time_zones for time zones.
Did anyone use the function?
Wim
dr.nybble
Excel Version: Excel 2007
Re: NewDateFormatter
Post by dr.nybble »
The TM1 function NOW returns a value that is interpreted as UTC time.
So you need to pass 'Etc/UTC' as the timezone when formatting it.
Passing a different timezone would be useful if, for example, you were parsing timestamps that were not UTC but a local time.
Thank you for the reply, that makes sense.
