Hi Users,
We a have a time dimension in our model it goes down from year till date. A user is requesting for another month only dimension along with the time dimension.
They wanted to build out ome reports where they can lay out months on the rows and years on the columns or vice versa.
We can do it using some calcualtions with one dimensions , but they wanted this so that they can slice an dice by month an year in same visualization .
How do you guys handle it and is it okay to ad a month only dimension .
Months and TimePeriod
- paulsimon
- Version: PA 2.0.5
Re: Months and TimePeriod
If you are actually on PA, then you should be able to use Named Hierarchies to do this. This is because with Named Hierarchies in a dimension you can show one Named Hierarchy on the rows and another on columns,
I assume that at present, you have one dimension with months like 2020-01, 2020-02 -----2020-12, 2021-01, 2021-02, etc
If you create a Named Hierarchy called Months with say February as a consolidation of 2020-02, 2021-02, March as a consolidation of 2020-03, 2021-03, etc. On its own in your single time dimension this is meaningless. I will assume that in your Time dimension you already have consolidations for months to years, so you have 2020 as a consolidation of 2020-01 ... 2020-12.
This should mean that you can select your Months Named Hierarchy on the columns, and your default hierarchy with the Year consolidations on the rows.
Although in your Months Named Hierarchy the February consolidation is made up of 2020-02, 2021-02, etc, when you combine this with rows that show eg 2020 and 2021, then you should see that in the cell for February with 2020, you only see the figure from 2020-02.
If you can give it a try and let me know if it works, I will update my time dimension generator to incorporate this. So far it has not really been a requirement at my current client.
If you are not yet on PA, then the only real option to do this is a virtual cube, ie you create a cube with separate month and year dimensions and you rule the data cross to it.
- OLAP Product: IBM TM1, Planning Analytics
- Version: PA 2.0.5
Hi Paul ,
We are on PA only , the current time dimension we have is like below
Year ,Month and Date .
2020
Jan 2020
20200101
2021
Jan 2021
20210101
so do you want me to create a alternate hiearchy with just months in it .
Months
what months should it have ,
I wanted something like this
Jan Feb Mar Apr etcc. Dec
2020
2021
2022
so my current month is Jan 2020 or 202001 , how can i make just jan , feb on the hierarchy should it be an sttribute on the months ..
2020
Jan 2020
20200101
2021
Jan 2021
20210101
Months
2020
2021
2022
- paulsimon
- Version: PA 2.0.5
Hi Manu
You need to create a proper Named Hierarchy, not just an alternate hierarchy. Check the TI Reference guide.
Do not bother with Attribute Hierarchies. Create a Named Hierarchy, and use HierarchyElementInsert and HierarchyElementComponentAdd to build the month consolidations.
- paulsimon
- Version: PA 2.0.5
Hi manu
I have updated my Month Dimension Generator to include a Period Totals Named Hierarchy. This includes consolidations giving the sum of the same period across all years, and a Full Year consolidation of those periods. With this, in PAX or PAW you can use, for example, the Periods and Full Year subset on the F4_Per_Tot Named Hierarchy on the Columns and the Year level of the F4_YHQM Named hierarchy on the Rows. (The F4 prefix means that the Financial Year starts in April, since obviously what is considered Period P01 is different if the company uses eg the Calendar Year as its Financial Year. The generator allows you to generate dimensions that include the Calendar Year and Financial Year(s) starting in any period you want.
It is free to download via our web site [url]http:www.successcubed.co.uk[/url]
I would hope that this finally puts the one or two time dimension debate to rest, but I doubt it.
- Periods on Cols Years on Rows Two Dims from One.jpg (58.48 KiB) Viewed 7172 times
- Harvey
- Version: TM1 8.3 onwards
- Excel Version: 2003 onwards
No, it does. Best of both worlds.
For actuals reporting and modelling I agree.
But split time dimensions still have a place in data entry which is enabled via spreading. E.g. use case relative proportional spread from Version A Year N to Version B Year N+1. With a single time dimension you can't do this.
- Harvey
Yeah fair enough. I tend to use and encourage data copy processes for that kind of thing, but it is nice to have the data spreading option in many cases.
