PAW not working after network changes
- gtonkin
I have a Win 2016 server running under Hyper-V. I moved the disk image from one host to another which also required new Network Adapters as the virtual switches are different. There are 2 adapters currently bound but only one will ever be active.
PAW was working just fine but now after starting the Admin tool to change the IP addresses, I cannot validate the Application Server Gateway:
My ethernet address is: 192.168.0.30 and the HNS is 172.30.80.1
I can login in to TM1Web, TM1, PAX etc. (Obviously cannot access the editor to change elements/members)
I cannot connect to PAW as it is probably not configured correctly yet.
All PAW processes other than Initialization say Running, Initialization says Completed.
I have tried the following so far:
-Numerous restarts and curses
-Changed the Interface Indexes for the new adapters to be lower than those of the HNS adapter
-Ran NETSTAT -a to see what ports are listening (listing what I think is relevant):
172.30.80.1 ->53, 139
0.0.0.0 -> 5010, 5498, 5895, 5898, 5985, 7999, 9510
I am not seeing anything listening on port 80 yet - expecting this for the PAW login/form
Any suggestions would be very welcome - thanks in advance.
- Excel Version: Excel 2007
Re: PAW not working after network changes
404 means you are talking to the application server, but the /pmhub/pm URL is returning 404.
Make sure PMHub is running. Or if you don't care about PMHub you can ignore it.
You also do not see anything bound to port 80 through the Docker NAT networking with netstat.
Try running scripts/launch.ps1 to connect directly to the PA Gateway container.
- gtonkin
Thanks for the response Dr Nybble.
.\scripts\launch.ps1 opens a tab on the browser - http://172.30.88.232/login?cburl=%2F but returns error 500.
I configured config\paw.ps1 with the IP Address the VM is using and tried to access the PAW login from the host machine (i.e. not same as where PAW is running due to the NAT issue).
I get this error now from on http://192.168.43.33/login/form - "Path not exist"
Going to http://192.168.43.33 redirects to http://192.168.43.33/login?cburl=%2F and gives:
Logs view view the admin tool, for Gateway process shows nothing adverse httpd.pid and id.
In the logs\pa-gateway, the *error* log has issues with the FQDN:
I have used the IP Address everywhere to try avoid this but not sure if the above is a red herring.
Will keep reviewing and reading.
Please let me know if there is anything further I can try or information I can supply.
PA-GATEWAY Error: An unexpected error has occurred. See the server logs for more information
AH00558: httpd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::9d51:833:f4ed:4927. Set the 'ServerName' directive globally to suppress this message
Look at the wa-proxy logs to see what is throwing the 500 error
The login/form endpoint is not used any more -- all authentication is now handled by the wa-proxy container
- gtonkin
Thanks Dr Nubble - the wa-proxy log is below-It contians the original IP Address (192.168.11.113), not the current 192.168.43.33.
My GO_New_Stores model is running and I can log in via Architect. Does not contain any IP Addresses or hard-coded names:
I am not sure where PAW is getting the 192.168.11.113 address from.
Please could you review and let me know if there is something else I should check/change. Thank you.
2018-09-17T17:52:51.645Z - error: PA-GATEWAY Error: An unexpected error has occurred
{ statusCode: 500,
message: 'PA-GATEWAY Error: An unexpected error has occurred',
error: 'Error: Failed TM1 login request: Error: connect ETIMEDOUT 192.168.11.113:5010',
stack:
[ 'Error: Failed TM1 login request: Error: connect ETIMEDOUT 192.168.11.113:5010',
' at C:\\wa-proxy\\auth\\tm1-strategy.js:283:9',
' at tryCatcher (C:\\wa-proxy\\node_modules\\bluebird\\js\\release\\util.js:16:23)',
' at Promise._settlePromiseFromHandler (C:\\wa-proxy\\node_modules\\bluebird\\js\\release\\promise.js:512:31)',
' at Promise._settlePromise (C:\\wa-proxy\\node_modules\\bluebird\\js\\release\\promise.js:569:18)',
' at Promise._settlePromise0 (C:\\wa-proxy\\node_modules\\bluebird\\js\\release\\promise.js:614:10)',
' at Promise._settlePromises (C:\\wa-proxy\\node_modules\\bluebird\\js\\release\\promise.js:689:18)',
' at Async._drainQueue (C:\\wa-proxy\\node_modules\\bluebird\\js\\release\\async.js:133:16)',
' at Async._drainQueues (C:\\wa-proxy\\node_modules\\bluebird\\js\\release\\async.js:143:10)',
' at Immediate.Async.drainQueues (C:\\wa-proxy\\node_modules\\bluebird\\js\\release\\async.js:17:14)',
' at runCallback (timers.js:574:20)',
' at tryOnImmediate (timers.js:554:5)',
' at processImmediate [as _immediateCallback] (timers.js:533:5)' ],
target: 'https://192.168.11.113:5010/api/v1/ActiveUser',
request:
{ method: 'GET',
url: '/login?cburl=%2F',
remoteIp: '::ffff:172.30.82.220',
headers:
{ host: '172.30.82.220',
accept: 'text/html, application/xhtml+xml, image/jxr, */*',
referer: 'http://172.30.82.220/',
'accept-language': 'en-US',
'user-agent': 'Mozilla/5.0 (Windows NT 10.0; WOW64; Trident/7.0; rv:11.0) like Gecko',
'accept-encoding': 'gzip, deflate',
dnt: '1',
cookie: 'paSession=eyJpZCI6IkdyZjhBZlNNdHh3SE1hTE84bkVHYzFaekMzclRvNzNmIiwiY3JlYXRlZCI6MTUzNzIwNjc1MH0=',
'x-forwarded-proto': 'http',
'x-forwarded-for': '172.30.80.1',
'x-forwarded-host': '172.30.82.220',
'x-forwarded-server': 'pa-gateway',
connection: 'Keep-Alive',
'ba-watson-gateway': 'location=http://wa-proxy:1331;',
'ba-sso-authenticity': 'blank',
'ba-sso-user': 'uid=;mail=;cn=Anonymous;loginId=anonymous;loginIdSource=;sessionUUID=Grf8AfSMtxwHMaLO8nEGc1ZzC3rTo73f;',
'ba-cam-passport': '',
'ba-scx-subscription': 'tid=null;userid=null;accountid=null;partid=anonymous;',
'ba-process': 'enabled=false;',
'ba-share': 'enabled=false;',
'ba-admin': 'enabled=false;',
'ba-modeling': 'enabled=false;',
'ba-social': 'enabled=false;',
'ba-common_save': 'explicit=false;',
'ba-graduatedui': 'enabled=false;',
'ba-welcome': 'largeUpload=disabled;multi-user=enabled;enableWebsheets=true;customFolders=enabled;globalAsk=false;newSamples=false;useCollect=true;smallBanner=true;isBIBannerEnabled=false;isWABannerEnabled=false;',
'ba-gemini': 'profile=prod;dimensionEditor=enabled;dimensionEditorNewTab=enabled;alternateHierarchy=enabled;allowDynamicSetToStaticInSetEditorWidget=enabled;uploadDataset=disabled;supportMDXInWebsheets=enabled;supportSelectHierarchies=enabled;',
'ba-tm1servers': 'prod=%5B%7B%22host%22%3A%22192.168.11.113%22%2C%22isSSL%22%3Atrue%2C%22port%22%3A5898%2C%22tcpPort%22%3A5498%2C%22servers%22%3A%5B%5D%7D%5D;',
'ba-cam-servlet': 'url=http%3A%2F%2Fibmcognoshost%3A9300%2Fp2pd%2Fservlet%2Fdispatch;' } },
worker: 6 }
[TM1S]
DistributedPlanningOutputDir=tunit
PersistentFeeders=T
ForceReevaluationOfFeedersForFedCellsOnDataChange=T
DataBaseDirectory=datafiles
LoggingDirectory=logfiles
ServerName=GO_New_Stores
PortNumber=45557
AdminHost=
Language=eng
Protocol=tcp
AllowSeparateNandCRules = T
NetworkFrame=
SaveTime=
DownTime=
RuleTraceOn=
RunningInBackground=T
EnableNewHierarchyCreation=T
HTTPPortNumber=5010
EnableTIDebugging=T
UseSSL=T
IntegratedSecurityMode=1
Verify that the config/paw.ps1 file contains the correct values (if you clicked "Update" in the Administration Tool it should).
If so, run scripts/paw.ps1; this should cause the bss-init service to run and update the user profile with the correct URLs.
- gtonkin
Hi Dr Nybble, think we are getting closer.
After executing paw.ps1 and starting the Admin tool, I am able to validate and update again.
When checking services however, Gateway shows as Exited, no logs found for Gateway (and in the PA-Gateway folder)
Restarting the server causing the Admin tool to exit with an exception: Execution failed with exit code 1
I have tried rebooting after a successful update but starting the Admin tool and checking services always shows that the Gateway service has exited.
What can you recommend?
Thank you.
Edit: tried to start PA-Gateway manually via Docker start PA-Gateway and received:
Error response from daemon: failed to create endpoint pa-gateway on network nat: HNS failed with error : The object already exists.
Error: failed to start containers: pa-gateway
Edit 2: ran 'docker system prune' and restarted the admintool - may have broken the PA-Gateway as it just says Created and status is ? - starting it crashes the admintool with the error above.
Thank you.
The joys of Docker on Windows!
Try to use the Microsoft-supplied tool to clean up the networking:
https://github.com/MicrosoftDocs/Virtua ... Networking
- gtonkin
Definitely lots of fun!
No joy yet however - I have tried the script and run it with the cleanup.
At this stage I think I may need to re-install - my PA-Gateway service will just not start and seems to crash the Admin Tool each time.
Going to give this a break for a day or two and see if a fresh mind sorts it.
I have had some success with the Microsoft script with the -ForceDeleteAllSwitches option. Hope Microsoft fixes whatever the underlying issue is that causes the networking to get in a messed up state.
- gtonkin
Thanks Dr Nybble, will try this in October. Had to take a week’s leave to get over the anguish it has caused.
- gtonkin
The -ForceDeleteAllSwitches option did not work, if anything I seem to be worse off now. I think it is truly broken now.
Is there a way to start from fresh?
I have tried removing docker completely, re-installing and re-installing the Docker images. Somewhere there still seems to be settings or configuration that I need to remove, re-initialise.Is there a way to start from fresh?
- gtonkin
Thanks Dr Nybble, had happened on the zap tool a couple of hours ago and uninstalled, zapped, reinstalled, recreated PAW from images, busy reconfiguring etc.
Will post back once all is done...
- gtonkin
After re-installing, everything seems to be up and running except there is no Gateway service??????
Docker images does show the image is available.
Is there a way to manually create and trigger the Gateway service - it should happen automatically.
- gtonkin
Something definitely not right with PAW on this machine - after all that, my windowsfilter folder is now 70Gb again and cannot start services as there is no space left on my device.
- gtonkin
Making some progress but the Admintool is having issues starting:
Using process explorer, I can see that System as a handle on all the windowsfilter folders but not sure what else could be locking or why.
Any suggestions?
Removing admintool
Recreating 92bea6393ef1_admintool ... error
ERROR: for 92bea6393ef1_admintool driver "windowsfilter" failed to remove root filesystem for 92bea6393ef1e623c547668c4
797401ed11357d8b3fe4f4333db4200b6a40c51: rename C:\ProgramData\docker\windowsfilter\92bea6393ef1e623c547668c4797401ed113
57d8b3fe4f4333db4200b6a40c51 C:\ProgramData\docker\windowsfilter\92bea6393ef1e623c547668c4797401ed11357d8b3fe4f4333db420
0b6a40c51-removing: Access is denied.
ERROR: for admintool driver "windowsfilter" failed to remove root filesystem for 92bea6393ef1e623c547668c4797401ed11357
d8b3fe4f4333db4200b6a40c51: rename C:\ProgramData\docker\windowsfilter\92bea6393ef1e623c547668c4797401ed11357d8b3fe4f433
3db4200b6a40c51 C:\ProgramData\docker\windowsfilter\92bea6393ef1e623c547668c4797401ed11357d8b3fe4f4333db4200b6a40c51-rem
ERROR: Encountered errors while bringing up the project.
Any suggestions?
There is a logged defect for Docker that you may be hitting. It is related to a daemon setting, 'shutdown-timeout'.
https://success.docker.com/api/articles ... ainers/pdf
See if a reboot fixes it (it would unmount the VHD).
Generally, the better performing your Windows 2016 system the fewer issues you see. How many cores does your system have?
- gtonkin
Thank you for the link - will have a read through it shortly.
My VM has 12 processors assigned and 16Gb RAM, 10.8Gb currently in use.
When running >docker ps, I am expecting to see PA_Gateway but do not see it. It somehow did not get added. I did try the upgrade/install option again when starting the Admin Tool but without success. All other services seem to eventually enter a running state, other than Initialization.
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
5e482ca0cf7c pa-docker:5000/planninganalytics/admintool:1.0.72-windowsservercore "powershell -Comma..." 2 days ago Up 2 days 0.0.0.0:8888->8888/tcp admintool
5e4995e4afd8 pa-docker:5000/planninganalytics/wa-proxy:1.0.247-windowsservercore "powershell -Comma..." 2 days ago Up 2 days 1338/tcp wa-proxy
c2e915bda48f pa-docker:5000/planninganalytics/share-platform:1.0.55-windowsservercore "powershell -Comma..." 2 days ago Up 2 days share-platform
9bfb9bc7cdf5 pa-docker:5000/planninganalytics/welcome:1.0.185-windowsservercore "powershell -Comma..." 2 days ago Up 2 days welcome
854e7db2ec82 pa-docker:5000/planninganalytics/prism-app:1.0.3022.2-windowsservercore "powershell -c C:\\..." 2 days ago Up 2 days prism-app
9666319ce8f4 pa-docker:5000/planninganalytics/prism-platform:1.0.856-windowsservercore "powershell -Comma..." 2 days ago Up 2 days prism-platform
14dc6ff2fec3 pa-docker:5000/planninganalytics/share-proxy:1.0.119-windowsservercore "powershell -Comma..." 2 days ago Up 2 days share-proxy
16a342f3ed85 pa-docker:5000/planninganalytics/share-app:1.0.24-windowsservercore "powershell -Comma..." 2 days ago Up 2 days share-app
d377f88f1077 pa-docker:5000/planninganalytics/redis:2.8.2402-windowsservercore "powershell -Comma..." 2 days ago Up 2 days 6379/tcp redis
88eefad393cf pa-docker:5000/planninganalytics/mongo:3.2-windowsservercore "mongod --smallfil..." 2 days ago Up 2 days 27017/tcp mongo
15435c156593 pa-docker:5000/planninganalytics/bss-init:1.0.80-windowsservercore "powershell -Comma..." 2 days ago Up 2 days bss-init
fa1a3653f86f pa-docker:5000/planninganalytics/couchdb:2.0.0.1-windowsservercore "powershell -Comma..." 2 days ago Up 2 days 5984/tcp couchdb
3ae9e16d30b6 pa-docker:5000/planninganalytics/couchdb_init:1.0.213-windowsservercore "powershell -Comma..." 2 days ago Up 2 days couchdb_init
1ff9c9b6a58f pa-docker:5000/planninganalytics/neo-idviz:1.0.232-windowsservercore "powershell -Comma..." 2 days ago Up 2 days 9060/tcp neo-idviz
d268a1532a21 pa-docker:5000/planninganalytics/bss:1.0.269-windowsservercore "powershell -Comma..." 2 days ago Up 2 days 8082/tcp bss
e02003c4c542 pa-docker:5000/planninganalytics/user-admin:1.0.112-windowsservercore "powershell -Comma..." 2 days ago Up 2 days 3333/tcp user-admin
168487d24fc2 pa-docker:5000/planninganalytics/cdn3p:1.0.61-windowsservercore "powershell -Comma..." 4 days ago Up 2 days cdn3p
be707525a55f pa-docker:5000/planninganalytics/prism-proxy:1.0.3819.1-windowsservercore "powershell -Comma..." 4 days ago Up 2 days prism-proxy
5547572128ad pa-docker:5000/planninganalytics/glass:1.0.336-windowsservercore "powershell -Comma..." 4 days ago Up 2 days glass
6d32646f3fb5 pa-docker:5000/planninganalytics/neo-provision:1.0.227-windowsservercore "powershell -Comma..." 4 days ago Up 2 days 8083/tcp neo-provision
Run:
scripts/paw.ps1
You may see all containers (including stopped ones) with docker ps -a
The initialization container will exit when it has done its job.
scripts/paw.ps1
