no format within IBM TM1 Applications
ckoenig
Post by ckoenig »
Hello all,
we have installed IBM Cognos Planning ( 2.0.3 ) Applications. If i call the pmpsvc everything works fine. Only that there is no style formatting inside,
I hope that someone can help me to find what it is worng with my install
see Schrren
screen TM1 applications.png (20.38 KiB) Viewed 2873 times
thx Chris
Edward Stuart
Version: All
Excel Version: All
Re: no format within IBM TM1 Applications
Post by Edward Stuart »
Does the same issue occur in alternative browsers? Are you using a supported browser from the software compatibility report?
IBM Software Compatibility Report
For PA 2.0.3 Local, Internet Explorer 11 is the prerequisite minimum required although you could expect some/ most of the functionality to work in prior versions
ckoenig
Post by ckoenig »
found the Solution. Reason was an old Custom Style we used comming from modified Version 10 Installation (doesnt work in v11 anymore).
