Anyone caould help me with a possible loop join issue ?
Thanks in advance to anyone willing to at leats advice something,
Join problem in FM
- OLAP Product: Transfomer
- Version: 7.3
- Excel Version: 2013
Join problem in FM
- IsThisaLoop.png (19.96 KiB) Viewed 59603 times
- Version: PAW 2.0.8
- Excel Version: 2019
Re: Join problem in FM
Hi tm1fmuser,Although name may sound bit similar this is not Cognos Forum rather it is Cognos TM1 Forum.
Please post your query in Cognoise forum under Framework Manager section:
http://www.cognoise.com/
https://www.ibm.com/developerworks/comm ... ags=cognos
http://businessintelligence.ittoolbox.c ... ognos10-l/ Thanks
- jim wood
- Version: PA 2.0.7
Bari,
It is a TM1 forum but we have sections for the likes of BI as TM1 interfaces with it. You'll also notice that we have forums for other products like Essbase. While your advise to post on other forums is sound, I wouldn't go driving people away just because of the title. If we wanted to do that then we'd close this section of the site down.
Fmuser,
It may take a while for you to get a reply here as the posting rate isn't that great, so I would also post this on the sites provided by Bari,
Fmuser,
Shop at Amazon
Shop at Amazon
- sachin
- OLAP Product: Transformer,SSAS, EP, TM1
- Version: 7.3 2005 10.1 10.1.1
Yes, alias shortcut is a way to address the join traps you see in the FM model. In the (g)olden days of Impromptu, we had the ability to define join weights and that was one way you could force the engine to generate the SQL path you'd want. It went way when Cognos ReportNet came on along with FM. We had put in a ENH request to bring that feature back into FM. It has been several years I last worked on FM. A lot might have changed, I am not sure if the join weights is introduced or not.tm1fmuser wrote:Hi,
You can find dozens of links in Cognoise or IT Toolbox regarding this problem.
- OLAP Product: TM1 (Windows) & SSAS 2014 Ent.
- Version: 10.2.0 FP3
- Excel Version: Excel 2013
I learning always to avoid modelling relations from Dim to Dim or Fact to Fact, but only let Dims touch Facts and vice versa. You could try to make first a join on all these Dim-tables to get a resultset ready to connect to the Facttable. Wrap this into an entity and join it to the Fact: Dim-Entity 1 .. N Fact. Some more similar stuff could be learned here: http://www.ibm.com/developerworks/data/ ... ge605.html
Note that FM is not a DBMS-Engine, but a tool to model entities under the special FM rules. Cognos generates from this queries in Cognos SQL which afterwards translates to the genuine SQL used by the DBMS. Check out here also: https://books.google.de/books?id=vQwYHs ... r.&f=false
Stefan
Stefan
