new to TM1, been using it about 3 weeks.
I set up a number of attributes on one of my dimensions that i need to replicate to another server. Everytime i run the replication the attributes do not appear in the new dimension despite the dimension being rebuilt. anyone know why this?
regards
Does Replication replicate Dimension Attributes
Re: Does Replication replicate Dimension Attributes
I'm not 100% sure about this but I don't think that replicating the dimension (as part of a data cube) automatically replicates the dimension's element attributes cube too.dubs wrote: new to TM1, been using it about 3 weeks.
The usual solution to this is to separately replicate the relevant }ElementAttributes_ cube as well.
You may need to select Display Control Objects from the View menu to see these cubes.
(Edited to remove some ambiguity.)
aha! yes this has worked, excellent stuff!!
thanks
thanks
