Setting Default Varibale content to "Other" in TI
gbehel
OLAP Product: TM1, Cognos EP, Contributor
Post by gbehel »
Hello All,
This is with respect to the Data Load using TI Process
After selecting the datasource and prevew data, when I go to variables tab, the default content for all the variables is "Ignore". Is there a way to set this default selection as "Other"
regards
Gbehel
Re: Setting Default Varibale content to "Other" in TI
No.
But you can select all fields in the variable type column and change the active dropdown (at the top or bottom of the column depending on which way you drag the selection) and change that field to "other" and all values will be updated. Thus you only need to do this action once and not per variable.
gbehel
Post by gbehel »
Thanks Lotsaram,
It helped. Considering i have around 290 variables in one data load file, this suggetion helped in making it quick.
Gbehel
