AttrS versus CellGetS from }ElementAttributes_ cube
sachin
OLAP Product: Transformer,SSAS, EP, TM1
Version: 7.3 2005 10.1 10.1.1
Post by sachin »
In an application that I am inheriting, I see in almost every TI use of
CellGetS ('}ElementAttributes_Dim_Name', element1, element2)
While we have always been using
 AttrS ('Dim_Name', element1, element2)
... where element2 is the attribute name we are interested in. The processes in question are used for data load into TM1 cubes.
To summarize, the approach used to get an element's attribute involves going to the control cube and getting the value. While we have traditionally been using built-in function of AttrS or AttrN to get the value.
Is there an advantage of one over the other, be it in terms of maintenance or performance or locking etc? I can't think of any; however, I am curious to hear how others weigh on this usage.
Thanks much!
Gabor
Re: AttrS versus CellGetS from }ElementAttributes_ cube
Post by Gabor »
CELLGETS returns a blank field for an Alias not set for a particular element. ATTRS refers back to principal element.
sachin
Post by sachin »
Thank you Gabor for your reply. Since I haven't heard from others, I believe working with either of the approaches should be just fine.
I tested your scenario. It looks like I get blank with either of those approaches i.e. Created an alias attribute on a dim, but did not populate it. Using AttrS or CellGetS from the ElementAttributes cube both returned blank! We are on 10.1.1.
Gabor
Post by Gabor »
Good to give me this hint, I have retested it and you are right.
I was sure, I saw the other behavior when aliases were introduced to TM1 and also with some later versions. But maybe I have simply stored the wrong information in my "memory".
Gabor
I wrote about it here:
http://users.skynet.be/fa436118/wim/tm1 ... ias_EN.htm
(At least) in that version, the attributes cube was empty too.
buncikp
OLAP Product: TM1+Cognos Express
Version: 9.5.2+10.1+10.2
Excel Version: 2007+2010
Post by buncikp »
It's good to be aware of this as some MDX functions might be affected as well - for example ORDER function in MDX is not picking up aliases "populated" by default. The point is that TM1 engine uses element principal name whenever alias value for that element is technically empty in given }ElementAttributes cube, but some functions - as CellGets or MDX as above will not do this substitution.
sachin
Post by sachin »
This thread has given insight into the working of Aliases, which I was not aware of! Thanks all.
