Hello Team,
While opening the XYZ application in Cognos Insight Connected mode it's working fine but same application opening in Cognos Insight Distributed mode It will through an error.
Error Message: E2) Dimension "ABC.dim" file not found or file error.
We are not using the "ABC.dim" dimension in our application as well cube rules. Same dimension still exists in TM1 server.
Chittem.
Chittemreddy
- Version: 9.5
- Excel Version: 2003
java_to_tm1
- Version: 10.2
- Excel Version: Excel 2010
Re: E2) Dimension "ABC.dim" file not found or file error.
Chittem,
What version of TM1 are you using?
The Java_to_TM1 Convert
TM1 Version 10.1, 10.2, Cognos Insight 10.1, 10.2
Local: Windows 7 Professional, Excel 2007
Server: Windows Server 2008 64-bit
p.s. I have a healthy disregard for Performance Muddler.
Chittemreddy
- Version: 9.5
We are using TM1 10.2.0 and Cognos Insight 10.2.1. Thanks
Chittem.
Chittem.
