Tm1 Admin server "ferst start error"
Alex.EBS
OLAP Product: Tm1
Post by Alex.EBS »
Tm1 V. 10.1,64-bit
Windows 7 professional 64-bit
Hello!
I am trying to start the TM1 on the my local machine for personal use. After installation, I tried to run the admin server (first start) from Configuration and got only one word "error" it seems related with registration as window's service, more specifically it can not do that. I had an attempt to do that manually, but did not make the grade.
P.S. UAC is off and configuration starts as administrator.
Version: PA 2.0.7
Re: Tm1 Admin server "ferst start error"
Post by jim wood »
When you ran the install, did you run that as administrator as well?
Alex.EBS
OLAP Product: Tm1
Post by Alex.EBS »
Yes I did.
Version: PA 2.0.7
Post by jim wood »
Does the service appear in the windows service list? Have you tried changing the user used to start the service to an admin account if you can see it?
Alex.EBS
OLAP Product: Tm1
Post by Alex.EBS »
No, it Doesn't. Finally I uninstalled my version and took new install file. It was installed correctly, but when I started Admin server it asked me change configuration settings. I selected "no" and server started to work well , but the question confused me, please give the comment?
Gregor Koch
OLAP Product: Cognos TM1, CX
Version: 9.0 and up
Excel Version: 2007 and up
Post by Gregor Koch »
You question confuses me but here is the comment:
maybe start here
http://pic.dhe.ibm.com/infocenter/cbi/v ... 40120.html
