TI SQL performance issue
PeteB
OLAP Product: Planning Analytics Local, PAW
Version: PAL 2.0.6, PAW 2.0.45
Post by PeteB »
I am having a performance problem running a SQL statement from TI. The exact same query pasted into Microsoft Query will return the 78 rows in under a second, while in TI it is taking over 2 hours to preview the results. TI is using the same ODBC connection as Microsoft Query on the same Windows server TM1 sits on. The length of time TI takes for this query to preview is appears relative to the number of rows the query will return by changing the where criteria in the SQL statement
(e.g. ... AND AL3.department='6111501'
to ... AND AL3.department='7210201')
1 row takes 1 second, 5 rows 2 seconds, 11 rows takes 0 seconds, 9 rows takes 1 second, 29 rows takes 40 minutes. The SQL performance appears repeatable for each change in the departments tested.
The problem TI SQL is intended to be used as a drill-through process. There is already a TI process loading 10,000 summarised records into the cube from the same database using the same tables in a few seconds.
TI is using the ODBC connection to connect to a Sequel Server database. The SQL nor the Database do not appear to be a problem as Microsoft Query and Hyperion return the same rows using exactly the same SQL. The ODBC connection doesn't appear to be the problem as the other TI process is returning are significantly more rows based on similar SQL.
Does anyone have any thoughts?
For completeness here is a version of the problem SQL
SELECT
  AL1.age_bucket,
  AL3.insprkey,
  AL3.cr_officer_code,
  AL3.department,
  AL1.transaction_cat,
  AL3.account_no,
  AL3.account_name,
  AL1.debt_type,
  AL1.amount,
  AL1.transaction_key
FROM
  dbo.debt_history AL1,
  dbo.debt_history_info AL2,
  dbo.account AL3
WHERE
  AL2.src_sys=AL1.src_sys
  AND AL2.src_date=AL1.src_date
  AND AL3.src_sys=AL1.src_sys
  AND AL3.account_no=AL1.account_no
  AND AL3.reconc='01'
  AND AL2.src_sys='POLISY'
  AND AL2.src_year=2013
  AND AL2.src_month=7
  AND AL2.src_period='ACCT'
Here is the SQL which is summarizing, however returning significantly more rows.
SELECT
  AL1.src_sys,
  AL2.src_year,
  AL2.src_month,
  AL1.age_bucket,
  AL3.insprkey,
  AL3.department,
  SUM ( AL1.amount )
FROM
  dbo.account AL3
WHERE
  AND AL3.reconc='01'
  AND AL2.src_month = '7'
  AND AL2.src_year = '2013'
GROUP BY
  AL1.src_sys,
  AL2.src_year,
  AL2.src_month,
  AL1.age_bucket,
  AL3.insprkey,
  AL3.department,
  AL1.transaction_cat
nick_leeson
Version: TM1 10
Re: TI SQL performance issue
Post by nick_leeson »
Stupid question but how long does this take if the offending SQL is not in a drill-through process !!
Also without understanding your Tables , cardinality of data and Indexes , I would write the offending SQL as below
-- Restrict the Number of rows and then Join 3 tables
SELECT
AL1.age_bucket,
AL3.insprkey,
AL3.department,
AL3.account_no,
AL3.account_name,
AL1.debt_type,
AL1.amount,
AL1.transaction_key
FROM
dbo.account AL3
WHERE
AL3.reconc='01'
AND AL2.src_month=7
Hope this helps.
PeteB
Post by PeteB »
Hi Nick,
Sorry, I should have said I had already tested the SQL both as a drill-through process and a standard process, just in case there was difference. As far as I can tell there is no difference between the drill-through process and a standard process from a TM1 perspective.
Thanks for the SAL tips, I will check out your suggested changes to the SQL. I hadn't been as concerned with tuning the SQL given its excellent performance via Hyperion and Microsoft Query.
I am currently testing to see if one the additional columns is causing the problem.
nick_leeson
Version: TM1 10
From my experience and we use Drill Through's extensively to give users access to GL Data from their ERP's. The initial SQL request by TI generally takes a few seconds and the subsequent ones are generally few seconds.
Any luck with the ODBC Log ?
I'm by no means an expert but isn't SQL type sensitive?
You have
AND AL2.src_month=7
AND AL2.src_year='2013'
AND AL2.src_month='7'
in the two queries? Are you forcing SQL to do something different under the hood?
Steve
wissew
Version: 9.5.2; 10.2.2; 11
Excel Version: 2003 SP3 - 2013
Post by wissew »
Steve is on to something. The ' key is need to encapsulate the month and year code.
PeteB
Post by PeteB »
Hi Nick and Steve,
Thanks for your suggestions, but so far no luck. My main concern is why the same SQL code using the same ODBC connection returning the same data takes significantly longer in TM1 TI versus both Microsoft Query and Hyperion. In fact both Microsoft Query and Hyperion are too quick to see any discernible difference between them.
I confirmed the performance is not related to the data (columns) being returned by replacing the columns with text. Changing the code as Nick suggested
made no difference to performance either in TI or Microsoft Query.
Also, the ODBC log is not recording anything
– the trigger is 30000 milliseconds, which should be triggered by the SQL in question.
I investigated Steve’s observation
You have
AND AL2.src_month=7
as I was surprised both would even work. However, both return the same data and there is no changed to the performance. I removed the dates as a cause in the test code below. Current there is only one months data.
I think the problem is related to the SQL and TI may be multiplying, by a magnitude, a potential performance issue in the SQL? I have run the following SQL code as tests – Microsoft Query has a performance problem with any of the following code.
The following code performs poorly in TI only
SELECT
  AL1.amount
FROM
  dbo.account AL2,
  dbo.debt_history_info AL3
WHERE
 (AL2.department='6521401')
  AND (AL2.src_sys=AL1.src_sys
 AND  AL2.account_no=AL1.account_no
 AND AL3.src_date=AL1.src_date)
However removing a table works fine in TI and returns the same results it removes a table
SELECT
 AL1.amount
FROM
 dbo.account AL2
WHERE
 AND  AL2.account_no=AL1.account_no)
The following code performs fine in TI it returns the same results
SELECT
  AL1.amount
FROM
  dbo.account AL2,
WHERE
  (AL2.account_no IN ('A1280000002', 'A1280000004', 'A128T888888'))
I will talk to my DBA about indices to improve the SQL performance, but I don't get the performance difference in TI.
Is the Use Unicode opton checked in TI? I have seen SQL performance issues in TI when the database has Unicode data in it and this option is not checked.
PeteB
Post by PeteB »
Hi Tomok,
Thank you for your response
tomok wrote:Is the Use Unicode opton checked in TI? I have seen SQL performance issues in TI when the database has Unicode data in it and this option is not checked.
Yes the Use Unicode option is checked
PeteB wrote:Yes the Use Unicode option is checked
Try unckecking it. I have also seen factor 10 or more improvement by doing this. Although the unicode option is the default for ODBC datasources in TM1 the reality is that if you're not dealing with extended character sets then you don't need it.
PeteB
Post by PeteB »
Hi Lotsaram,
Thank you. Yes, unticking the "Use Unicode" has made a definite improvement on a number of queries. The one query which was taking about an hour and forty minutes is now down to about 10 minutes. But still not comparable to Microsoft Query is doing the same in about 1 second. I am now searching the forum for threads containing Unicode and ODBC - I had only looked for TI and SQL previously. There seems to be a number of options in the following threads
http://www.tm1forum.com/viewtopic.php?f ... ode#p42109 and http://www.tm1forum.com/viewtopic.php?f ... ode#p35743
rmackenzie
Post by rmackenzie »
Hi PeteB -
The issue you are facing is definitely one of the TM1 bugbears that crops up every now and then; I find it most frustrating as well. Although you've found a performance boost by not using the Unicode option, as the guys pointed out, the performance is still not matching other query tools - why? When you run a TI that uses an ODBC data source, TM1 does two things: firstly, it issues the query via the driver and is returned a result. Second, AIUI, it caches some (or all) of the results into memory for processing by the TI script (depends on size).
The difference between TI and other SQL query tools is that it only knows about numeric (real) and string data types. Therefore it has to convert the data values in the results to the correct type. E.g VARCHAR becomes string, INT and FLOAT become numeric etc. Sometimes it is going to encounter column types that aren't supported (TM1TypeSQLNotSupported). This all takes time and other SQL query tools probably handle this issue in a different, more efficient way. As TI processes its way through the results, this post-processing is, IMO, the reason for the performance issue.
So, I would try re-writing the query in such a way that each column is cast into a well-known type (CHAR, VARCHAR, DATETIME, INT, REAL, FLOAT etc) that is easily parsed by TI. Also, I would re-write the query such that the joins between tables are explicitly defined and that the constraints are expressed per the data type. E.g. if the column is INT then var=2013 and not var='2013'.
I've encountered one or two queries that simply wouldn't process over the years so heres hoping this isn't the first for you ;)
Robin Mackenzie
PeteB
Post by PeteB »
Hi RMackenzie,
Thank you for your great explanation on how TI was working differently to the other tools in regards the ODBC connection. And thanks for your suggestions as well.
I have tested out your suggestions but did not get the results I was expecting, so I just wanted to clarify if I have followed them correctly. Firstly, I hoped to eliminate the parsing issue by simply returning a 1 in each row. Secondly, in the examples below, I have matched the constraints and their data types. Finally, I have performed the explicit joins. However I am still getting unusual performance results.
-- This SQL is taking over 10 seconds and returns 1 million number of rows
SELECT
   1
FROM
  dbo.debt_history AL1 INNER JOIN dbo.debt_history_info AL3     ON AL3.src_sys=AL1.src_sys AND
  AL3.src_date = AL1.src_date
   INNER JOIN   dbo.account AL2  ON
  AL2.src_sys=AL1.src_sys AND
WHERE
  AL2.reconc='01'
-- This code is taking over 500 seconds to return 800 rows
SELECT
   1
FROM
WHERE
  AL2.reconc='02'
I am still hoping this is not going to be one of those queries you mentioned.
kugors
Version: 9.5.2
Post by kugors »
I had similar issue while loading result data to TM1. I used workaround to deal with it. I created table in SQL with columns from select and function that's populate this table with data. I placed this function in prolog of TI and put simple select * from table in query. In My case it worked.
HTH
rmackenzie
PeteB wrote:Firstly, I hoped to eliminate the parsing issue by simply returning a 1 in each row.
Although I agree TI shouldn't have much trouble understanding that 1 is a number, I'd still be tempted to assign explicit types to the columns simply to eliminate the possibility that TI is looking at the column type itself and not the type of the field value in order to discern the type for TI. I.e. value of 1 could still be in a field of a non-integer type.
PeteB wrote:Secondly, in the examples below, I have matched the constraints and their data types. Finally, I have performed the explicit joins. However I am still getting unusual performance results.
Looks good - amazing that AL2.reconc='01' and AL2.reconc='02' are causing such a difference in performance - at this point it looks like you've hit one of those problem queries. Although it clearly looks like a TM1 issue, are you able to test with a different ODBC driver, or even different RDB stack?
Robin Mackenzie
