Migrating TM1 code to other regions
sirib
Version: 10.1.1
Post by sirib »
I am new to TM1 tool and wondering if I can get some help in regards to migrating the TM1 code from developement regions to other regions and also is there a way where we can migrate the code like processes, cubes, applications and dimension and with out migrating the data.
Sirib
Re: Migrating TM1 code to other regions
Since you are new I will go easy and basically tell you to use the search tool on this web site. This very topic has been discussed ad naseum, no need to repeat anything right here. You will find plenty of posts on topic.
sirib
Version: 10.1.1
Post by sirib »
Thanks, I will search for it, quick question, is it possible to migrate just the code and not the data along with code?
Quick answer: yes.
