I was able to find a IBM article on how to create a csv file with a list of the dimensions and what cubes are using the dimensions. I was wondering if anybody has tried to do this but determining the which dimension are being used as a picklist.
Just for maintenance purposes, I was just wondering if anybody tried it.
List Measure Dimensio using Dimensions or Subset as Picklist
appleglaze28
- Excel Version: 2003
Re: List Measure Dimensio using Dimensions or Subset as Pick
Hello
I never did create such a process, but it isn't that hard.
I limited myself to a loop over ElementAttributes control dimensions, testing whether there is a text element (attribute) called Picklist.
If needed, add a loop to check Picklist control cubes, but that might be harder to do.
See attached TI process, it will create a text file in the database directory for the TM1 server concerned.
Wim
Wim
- Overview of picklists.pro
- Wim Gielis
- (3.84 KiB) Downloaded 465 times
Updated coding, more functionality provided. Still only }ElementAttributes_* dimensions are treated.
- Overview of picklists_V2.pro
- Wim Gielis
- (5.17 KiB) Downloaded 466 times
Last addition for now, a loop over cubes was added.
The code always generates 2 text files as output.
Wim
Wim
- Overview of picklists_V3.pro
- (7.09 KiB) Downloaded 468 times
appleglaze28
It seems that you are online here, but did not provide any feedback in your own topic.
I spent quite some free time to answer your question - it would be most polite to at least comment on the solution given.
If anything is unclear or should be changed, that could still be done.
Wim
Wim
