- Cognos Express 10.1 Xcelerator client
- CAM authentication (through AD)
We installed several client workstations. Some of them run properly. But on the others the logon page doesn't show (nothing happens after double-clicking on the TM1 server).
It works fine on the server itself and on one other computer.
I tried to open all ports without success. If I call the CAM url directly in IE it works fine.
Does anyone have an idea? I don't know in which direction I should investigate. It looks like when to TM1 servers are using the same port but I'm sure it is not and some client work fine. I don't use the default database directory but I re-installed the cxmd service to point to my new .cfg file. I downloaded the client setup .exe from the welcome page only once and reused it for every new installation.
I'm used to TM1 (13 years working on it and I can't remember having installation problems) but each new Cognos Express setup is full of surprises...
And by the way, does anyone knows why is Xcelerator Client so long to setup?
Aude
