If You Could ask the TM1 Development Team a Question.......
How can I see TM1 views and subsets in Cognos BI 10.2
I am looking for the best way to expose TM1 cube views and subsets in Cognos Report studio
I have some complex TM1 cubes packaged with Framework Manager, they all have multiple complex views and subsets, It will take a few days to rebuild in Report Studio the same logic.
As far as I understand, it is not optional to see TM1 views and subsets in the Cognos BI environment.
I considered opening the views in Cognos Insight and publishing them, however the customer looses the ability to switch between viewed and subsets, any suggestions? Also once published the user will have to manage the view twice, any update in TM1 will have to be replicated in BI or republished.
Exposing TM1 cube views and subsets in Cognos Report Studio
- Version: 9.5 10.1 10.2
- Excel Version: 2003 2007
Reason: Split from the "If you could ask the development team a question" topic; this sort of question wasn't intended for that as per Jim's first post in it.
- Excel Version: Office 2010
Re: Exposing TM1 cube views and subsets in Cognos Report Stu
As I understand the tools, currently views and subsets are not available in Cognos Report Studio.
A common approach is to build a specific TM1 cube for reporting from Cognos - structure your dimensions with the consolidations and subsets that are required specifically for <i>reporting</i>.
