Limit rule based on attribute
mitch23
Post by mitch23 »
I have a pretty simple G/L cube with the dimensions Entity, Account, Job, Period, Version, Measure. Each element of the Job dimension "belongs" to an element of the Entity dimension and that relationship is specififed via an "Entity" attribute of the Job. I want to write a rule and have that rule apply only if the Job "belong" to the Entity being evaluated. Something like:
['(area definition)'] = N:IF(ATTRS('Job', !Job, 'Entity')@=!Entity, [value if true], CONTINUE);
This syntax is not valid of course but it illustrates what I'm trying to accomplish. Any suggestion would be greatly appreciated. I'm sure I'm goikng to feel stupid when someone shows me the obvious solution :-)
Re: Limit rule based on attribute
This syntax is correct! At least, on a Sunday evening I don't see anything wrong in the rule.
Obviously, you need to:
- provide a valid area on the left
- have the same kind of values in the Entity elements and attribute values for Entity
- specify [value if true] correctly
Also, I'd route the False part to 0 rather than CONTINUE, unless you have a special plan for this slice of the cube.
Wim
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Post by Andy Key »
Try switching
to
!Entity@=ATTRS('Job', !Job, 'Entity')
I'm sure I've had issues in the past with the former, and fixed it with the latter.
Andy Key
