Weighted Cost Issue
pablo
Version: 9.5.2
Weighted Cost Issue
Post by pablo »
I need urgent help with a weighted formula. Currently I am using a ConsolidateChildren to calculate the Weighted Measure. I am aware that this has an impact on the RAM and performance and so does the client by now.
I cannot get any way around this.
My formulas:
## At an All Activity level it is a Total Case Cost and not a Case Cost.
['Case Cost']=
If (!Activity @= 'All Activities',
ConsolidateChildren('Activity'),
['Total Activity Cost']\['Cases']);
###I think that this rule is the issue.
###On a Item level the Case Cost and Weighted CAse Cost will allways be the same. But if Item is a grouping then Consolidate the children under the item grouping.
#Calculate Weighted Costs
#Cases
['Weighted Formula Calc']=
IF(ELLEV('Item',!Item)=0,
['Case Cost']*['Cases'],ConsolidateChildren('Item'));
##Again on a Item level the Case Cost and Weighted Case Cost will allways be the same, but the weighted formula calc measure is consolidated and not calculated at a item grouping level. Then take that Consolidated value and devide by number of cases and that give you a weighted case cost at that level.
['Weighted case cost']=
['Weighted Formula Calc']\['Cases'];
See view below:
This data is allready at a consolidated level. All Activities
I cannot get the table below in correct format. My fisrt post :oops:
838238 is the grouping that should be weighted.
181707.94 is the weighted formula calc that is devided by 60173 cases to get to the weighted case cost of 3.02
Items: Total Activity Cost Cases Case Cost Weighted Formula Calc Weighted Case Cost
838238 26 933.81 60 173.29 3.04 181 707.94 3.02
1162497 5 253.83 13 803.71 2.61 36 004.75 2.61
1162514 5 549.30 14 943.57 2.48 36 993.24 2.48
2869218 2 268.24 5 403.00 2.85 15 391.28 2.85
2869225 2 423.54 5 787.00 2.81 16 270.31 2.81
2869232 2 123.99 4 530.00 3.25 14 702.71 3.25
2869249 3 493.21 2 946.00 7.95 23 411.23 7.95
2869256 2 806.00 6 484.00 2.87 18 631.96 2.87
2869263 3 015.70 6 276.00 3.23 20 302.46 3.23
If I replace the above rule for 'Weighted Formula Calc' with rule below to not use consolidate children:
['Weighted Formula Calc']=N:
['All Activities','Case Cost']*['Cases'];
My performance is no issue and the RAM stay consitent but on a YTD or Q1 and Q2(not on a month) the weighted case cost is not weighted.
Any suggestions will be much appreciated.
Thank you
TM1 forum attachment.xlsx
Weighted Case Cost
(9.26 KiB) Downloaded 319 times
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Re: Weighted Cost Issue
Post by Duncan P »
Have you looked in this thread? http://www.tm1forum.com/viewtopic.php?f=3&t=7641
The similarities, particularly in the attachment, are remarkable.
