Action Button Security
Version: PA 2.0.7
Post by jim wood »
Guys,
I think I know the answer to this one but there you go.....
If a user wants to execute a process via an action button do they have to be within the data admin group? Is there any way to execute the process as a defined admin user?
Jim.
Lukas Meyer
Re: Action Button Security
Post by Lukas Meyer »
1: no, the user needs to be in a group that has read rights to the process associated with the action button.
2: I'm almost sure that in 9.1 and below the process started by a user still executed as administrator and only recently (when Data/Security Admin was used) certain process-functions (like SECURITYREFRESH) fail for non-admin users.
If you need to use p.ex SECURITYREFRESH in a process normally executed by a non-admin user, you can use TM1RunTi (packed in Tm1 9.5.2 HF1) by calling a bat executeable via EXECUTECOMMAND(path-to-script,0)
(bear in mind that the process calling might hold some locks you need in the process called by tm1runti and mode 1 (=wait) can easily provoke a deadlock)
TM1RunTi acceppts encrypted credentials, so you can execute processes as anyone.
This holds true for TM1 9.5.X, so if TM1 10.1 changes everything this might be completely wrong ;)
Version: PA 2.0.7
Post by jim wood »
Lukas,
Thanks for your help. Granting read access to the process did indeed do the job,
Jim.
Lukas Meyer wrote:Hello,
I'm not sure why you would go to the trouble of shelling out with RunTI and logging on in a new thread as a full admin user when all that needs to be done for a process to run as full Admin rather than Data Admin is to right-click the process and select "security access" which then allows the process to execute security functions.
Lukas Meyer
lotsaram wrote: I'm not sure why you would go to the trouble of shelling out with RunTI and logging on in a new thread as a full admin user when all that needs to be done for a process to run as full Admin rather than Data Admin is to right-click the process and select "security access" which then allows the process to execute security functions.
Honestly - because I didn't know. There are two processes refreshing security, I only ran into the problem of having non-admin users running one of them two weeks ago.
However, the official answer would be, that I like to explore the capabilities of TM1 and that I needed to get familiar with runti.exe, plus that it had advantages if this part of the process was executed by the administrator user.
