We are currently conducting tests on CX 10.1 regarding install, configuration and operational differences from 9.5.
I am wondering, however, if anyone has any experience or knows of any issues or points to watch out for regarding reverting back to CX 9.5 after an install of 10.1 and transferring the data to the older version ?
This is an open question rather than a support request.
Cognos Express rollback from 10.1 to 9.5
AlastairFM
- OLAP Product: TM1 / Cognos Express
- Version: PAL 2.0.9.1
rmackenzie
Re: Cognos Express rollback from 10.1 to 9.5
There have been problems noted in the past with trying to re-install CX on a machine that had an older install on it; no idea if this impacts 10.1->9.5 thoug... I'd say using a VM with a clean base image is the way forward here if you're just checking out the new version and whether you want to plump for the upgrade.AlastairFM wrote:any issues or points to watch out for regarding reverting back to CX 9.5 after an install of 10.1 ...
You are taking a back-up, aren't you ?AlastairFM wrote:and transferring the data to the older version ?
Robin Mackenzie
