Cognos Express 10.1
Cognos Express 10.1
...is now out.
More detailed announcements will follow, but if you think TM1 10.1 but cheaper, you won't be far off.
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
Re: Cognos Express 10.1
Key features
- Cognos Insight combined with Advisor module
- Performance modeller available for building apps
- Business insight available as portal as well as Cognos Connector
- Can put tm1 web sheets into workflow apps
- Cognos mobile, iPad reporting!
- Excel 2010 support
- jameswebber
- OLAP Product: Cognos Express 10
- Version: CE 10.1.1
Heres the download page...
http://www-01.ibm.com/support/docview.w ... wg24031399
waiting for IBM/Cortell to sort out my maintenance record so I can download
J.Tran
- Version: Cognos Express 9.5.0
Just downloaded and unpacked it. About to pop it onto a dev server to see what it looks like. Size of download is pretty big though.
CE 9.0.0 - 1.38GB
CE 9.5.0 - 2.41GB
CE 10.1 - 6.23GB
CE 9.0.0 - 1.38GB
CE 9.5.0 - 2.41GB
CE 10.1 - 6.23GB
winsonlee
- Version: 9.5
anyone knows if the new CE is using the new TM1 10.1 ICAS engine which supports multi read and multi write ?
yes_it_doeswinsonlee wrote:anyone knows if the new CE is using the new TM1 10.1 ICAS engine which supports multi read and multi write ?
winsonlee
- Version: 9.5
thanks for the info lotsaram. this will resolve most of the bottle neck that we are having with CE 9.5.
kpk
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
Performance modeller is only available for CEX Planner user:stephen waters wrote:Key features
http://www-03.ibm.com/software/sla/slad ... FF00372478
http://www-03.ibm.com/software/sla/slad ... 230048B42F
Best Regards,
Peter
Peter
- stephen waters
- Version: 10_2_2
Groan..... Not what I was led to believe. So, another couple of hours to be wasted reading through legal definitions written by people with no understanding of reality! From the link to things users can't do ( I think this explicit listing is new to 10.1) it seems only Planners can create objects with Performance Modeler, but most users can create ICAS\TM1 objects with Architect. Lucky them.kpk wrote: Performance modeller is only available for CEX Planner user:
Wouldn't it be nice to have a simple product with easily understandable user roles, eg , Developer, read\write and reporter. Easy to buy and easy to install.
nick_leeson
- OLAP Product: TM1 9x, BPC, Hyperion, HANA
- Version: TM1 10
- Excel Version: Excel 2003 - 2010
"Wouldn't it be nice to have a simple product with easily understandable user roles, eg , Developer, read\write and reporter. Easy to buy and easy to install." Not the IBM way unfortunately !
- jameswebber
Another one is that anyone receiving a custom burst needs a reporting licence or consumer license.
"Each person who has a personalized report output created for them by the IBM Cognos Express Administrator or IBM Cognos Express Reporter User must be covered by an Authorized User entitlement."
"Report bursting is a method of producing a set of reports containing personalized content that is based on a common report definition."
http://publib.boulder.ibm.com/infocente ... rstng.html
So, if you are bursting a report, it is considered to be personalised the recipient must be licenced.
This is not great at all.
I know this is drifting a bit from the topic of CX, but I've been advised that under our existing legacy Applix client licencing apparently we aren't even permitted to use Contributor or Performance Modeler without upgrading to Contributor licences, which would then give us Applications (nee Contributor), Cognos Insight, and PM. Those who know my views on PM will know that the latter is not causing me to rush to the company chequebook but the others may matter in the future.stephen waters wrote:From the link to things users can't do ( I think this explicit listing is new to 10.1) it seems only Planners can create objects with Performance Modeler, but most users can create ICAS\TM1 objects with Architect. Lucky them.
Well, there is... it's just not TM1.stephen waters wrote:Wouldn't it be nice to have a simple product with easily understandable user roles, eg , Developer, read\write and reporter. Easy to buy and easy to install.
http://www.microsoft.com/sqlserver/en/u ... nsing.aspx
Mmm, a 6 page .pdf, what you get, for how many dollars, all spelled out in straightforward, easy to follow language with the lowest amount of marketing-speak BS I've seen in any comparable document outside of maybe TechSmith[1]. I do so love SQL Server...
[1] TechSmith, makers of certain very fine niche market software such as Snagit, is too small to have a proper marketing department. Or if it does, it's one that doesn't hold sway over the business strategy. From a customer point of view, this is very much to our advantage as it means that their web sites and product information gets to the frapping point without all of the meaningless technobabble and dross that you need to wade through to find out what a product actually does on certain other corporate web sites. This of course helps the supplier too since more than once I've looked at their products, thought "Oh, that's cool, I want that!" and since I understood exactly what the product did and exactly how much it cost, bought it on the spot. It helps that they don't change the names of the software components with each release as well.
winsonlee
- Version: 9.5
apart form having the limitation of the 100 licenses for Cognos express 10.1, what other major difference there is between Cognos BI 10.1 + cognos tm1 10.1 ?
i have been testing it and it seems like CE 10.1 has all the new features eg Cognos Insight, Cognos Business Insight and cognos business insight advanced which is found on the Cognos BI 10.1 and Cognos Tm1 10.1.
earlier i would thought that there would be some changes on the Rules Editor and TI editor but it is still the same as CE 9.5. Has the rules editor changed on the TM1 10.1 ?
- jameswebber
I don't think there are any differences with Cognos BI and Cognos Express.
Has anyone had issues installing Congos Express Xcelerator Client?
I keep getting the error:
Please select another location to extract the installer to:
I have tried most of the steps listed here with no luck:
http://www-304.ibm.com/support/docview. ... wg21504274
winsonlee
- Version: 9.5
just a guess, have you tried right click on the file "Run As" an administrator ?
- jameswebber
That was my first try and running it from my documents and in compatibly mode
But thanks for the suggestion.
winsonlee
- Version: 9.5
did you have an earlier version installed previously ? did it uninstall successfully without giving any error ?
- jameswebber
Good idea!
But actually just rebuilt my laptop and the server from starch so both have no previous TM1 installs.
I'm thinking virus checker which a enterprise wide so a bit of an issue or a corrupt installer package.. neither are very good options.
Andy Key
- Version: 2.5 to PA
- Excel Version: Lots
CX (as a product that you can buy rather than trials or partner versions) is a 64-bit Windows product only.winsonlee wrote:apart form having the limitation of the 100 licenses for Cognos express 10.1, what other major difference there is between Cognos BI 10.1 + cognos tm1 10.1 ?
All CX components must run on the same hardware server with a maximum of 32 cores.
The integration of the various components relies on there being a single TM1/ICAS/Xcelerator server called CXMD.
CX is not licensed to use BI or another CX instance as a datasource, being limited to text and ODBC sources.
Given that CX instances are not allowed to talk to each other, there is no Replication.
CX Reporter is a limited set of the various Studios that are available for the full BI suite, so no Analysis Studio, no Event Studio, no Metrics Studio.
Andy Key
- jameswebber
Just FYI my:
Please select another location to extract the installer to: Error turned out to be a corrupt install from our IBM partner... things much better now
