I need some help on tm1 contributor.
I need to lock previous Quater data (Read) and keep opened for current Quarter for data submission for a particular user and for particular region.
I need to achieve this tm1 web contributor.
This need done in TM1 contributor admin? could you please advise steps?
Thank you
Ravi
TM1 web contributor problem
PlanningDev
- Version: 2.0.5
Re: TM1 web contributor problem
Not possible in TM1 contrib admin. However you could build a control cube that does to contain the elist and assign rights to whoever you would like. This way from any node view an end user could change the control cube which could change a rule dynamically. Of course you may need to do a security refresh somehow if using security control cubes for this but if you are simply rolling actuals you wouldn't need to.
If you are using TM1 10.1 then websheets are available in contributor and end users could control data and run processes from here.
