I have a problem. Trying to get our HR guys on board with TM1. They have a HR structure in our accounting system (SAP) called org unit. Here is my problem:
Consolidated items contain their own values that need to be added to the consolidation, as below.
CEO (1)
---- PERS (20)
---- IS (25)
---- FIN (30)
Should be:
CEO (76) (Note: the 1 added in)
---- PERS (20)
---- IS (25)
---- FIN (30)
TI won't post to C level. So I created a flat hierarchy dimension and cube which I can post the numbers to. How can I then trick the system into doing the roll up I want?
Hierarchy Hell
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: Hierarchy Hell
You indeed can't store data on a consolidated level. A typical way to get this working in TM1 would be to build the hierarchy like:
Total CEO (76)
---- CEO (1)
---- PERS (20)
---- IS (25)
---- FIN (30)
IMO this is also a more transparant way of showing where the numbers are located.
Michel
Total CEO (76)
---- CEO (1)
---- PERS (20)
---- IS (25)
---- FIN (30)
Michel
- Excel Version: Office 2010
Re: Hierarchy Hell
If they insist on having this method then you could store it as a String element against each level of the heirachy.
But, really. Fight this as strongly as possible.
- ADW
- Version: 9.5
Re: Hierarchy Hell
Hi Michael,
Thank you for your reply. I have implemeted this and it seems to work of (just need to adjust the TI to remove 'Total' group names with only one child). Certainly produces the numbers I need.
Christopher,
Appologies but I don't really understand your comment.
Adam
Christopher,
Adam
Re: Hierarchy Hell
Leave it the way you have it now, that is the preferred approach.ADW wrote:Christopher,
Adam
Christopher only commented in case HR still wanted to write values to consolidations. Try to avoid it as much as possible.
Re: Hierarchy Hell
I agree with Wim but just to answer ADW's question for future reference; level 0 data in TM1 comes in two flavours, N elements and S elements. N type stores (Numeric) values, S types (which can only appear in the last dimension of a cube) store "strings" (or text, for the non-technical).Wim Gielis wrote:Leave it the way you have it now, that is the preferred approach.ADW wrote:Christopher,
Adam
You can never write values directly to a numeric consolidation, but you can to a string consolidation. But, of course, if you store a value as a string you can't effectively calculate with it. (Slight oversimplification, but go with it.)
It's a way of working around your problem but as has already been stated you definitely shouldn't do it if you can avoid it.
- ADW
- Version: 9.5
Re: Hierarchy Hell
Thanks all for your excellent replies
