Insert Element in Dimension, Set Attribute
maps
Version: 9.4.1 and 9.5.1
Post by maps »
Hi everyone,
I'm struggeling with updateing a dimension. I just want to load the elements out of a textfile into a dimension and set a attribute 'Status'. But always the following error occurs:
...Data Source line (1) Error: MetaData procedure line (8): Element "10010." not found in dimension "dim_Empl".
Line 8 refers to the AttrPutS statement.
MetaData:
IF( DIMIX( cDimName, vPersID) = 0);
  DimensionElementInsert( cDimName, '', vPersID, 'N');
  IF( DIMIX( cDimName, vPersID) <> 0);
    AttrPutS( 'EXISTS', cDimName, vPersID, cAttrStatus);
  ENDIF;
ELSE;
  AttrPutS( 'ACTIVE', cDimName, vPersID, cAttrStatus);
ENDIF;
Because I always got the error I inserted the second DIMIX statement to ensure that the element of the dimension really exists. What am I doing wrong? Any ideas?
Edward Stuart
Version: All
Excel Version: All
Re: Insert Element in Dimension, Set Attribute
Post by Edward Stuart »
Edit: After engaging my brain I realised I was wrong!
Although checking through the help files for AttrInsert/ AttrDelete it doesn't mention where it needs to be placed in the TI process.
Last edited by Edward Stuart on Mon Jan 09, 2012 11:29 am, edited 1 time in total.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
Hi maps,
Please note that the dimension is only saved after the Metadata run has finished - so all elements that have been added will be available after the MetaData script has completed, this is at the start of the Data run.
Setting attribute values is in fact loading data in the corresponding }ElementAttributes cube. In order to be able to load data, the regarding cell to load needs to be available - this will be after the changes to the required dimensions have been saved. So loading the attribute values will be something you do in the Data tab script, not in the MetaData tab script.
Michel
maps
Post by maps »
But how can I set the attribute with the status? When the metadata tab has finished the element is already in the dimension and it doesn't make any sense to use the dimix statement again. How can I flag that the element didn't exist before using a flag? any advice?
Michel Zijlema
maps wrote:But how can I set the attribute with the status? When the metadata tab has finished the element is already in the dimension and it doesn't make any sense to use the dimix statement again. How can I flag that the element didn't exist before using a flag? any advice?
You could create a temporary dimension and list new elements in this dimension. On the data tab you could set the status based on the availablity of the element in this temporary dimension.
Michel
Michel Zijlema
Another option could be to have an alternative hierarchy called 'New elements' in your dimension and add the new elements to this alternative hierarchy. This way you don't need an attribute to flag new elements.
Michel
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
This is very similar to the problem discussed in this thread http://www.tm1forum.com/viewtopic.php?f=3&t=6669
Post by David Usherwood »
I've used another technique in the past:
a Have a working cube dimensioned by your dimension;
b Fill it with 1s before doing the dimension load;
c Then the elements showing 0 are the new ones.
David Usherwood wrote:I've used another technique in the past:
This forum should have a hat tip smiley. I'll have to add that one to the play list.
maps
Post by maps »
I had the problem that I have to distinguish between 3 different kind of elements of the dimension.
When I'm imoprting element to the dimension the element can be an "new one" (does not exist yet), "already existing". All other elements of the dimension (elements which are not in the import file are "old ones".
I implemented it now in the following way. I created a new tmp dimension "}blabla" added all the new elements in the metadatatab. The already existing one I could already flag in the metadata tab.
The new ones I flagged in the data tab. For this I iterated over all the elements of my new Dimension and inserted the value of the attribute. To make shure that this procedure is only executed once i used a flag I created in the prolog.
prolog
cFlag = 0;
datatab
if(cFlag = 0);
  cFlag = 1;
    While...
  ENd;
So I was able to flag "new" and "already existing" element. Elements which are not used anymore do not have a entry for the attribute...
