When I use following TI function in TM1 rule editor, I get below attached error......
Function Used: CellPutProportionalSpread(7704,'GL','expense','Engineering','2011','Actual');
I am not sure whether I can use this function under rule editor or not? if yes, Am I using this function correctly?
Regards.
TM1 Rule error...
TM1 Rule error...
- error.png (8.22 KiB) Viewed 2253 times
- Steve Rowe
Re: TM1 Rule error...
Pretty sure that you can't use that. Rule functions can _in general_ but with exceptions be used in TI. TI operations cannot in general be used in rules.
