Is there any way or functions available for error handling in TM1's TI process?
If errcode = 3604 then
else
endif;
Thanks in advance.
Error handling.
ryan
- OLAP Product: COGNOS
- Version: 9.0
Error handling.
Configuration Details
Microsoft Window Server 2003 Exterprise x64 Edition Service Pack 2
RAM 32 GB
using IBM Cognos Express Xcelerator (Version 10.1)
MS-Office Excel 2010 (12.0.6514.5000)SP2 MSO (12.0.6425.1000)
Microsoft .NET Framework 3.5
RAM 32 GB
Re: Error handling.
You wish. As, indeed, do most of us.ryan wrote:Is there any way or functions available for error handling in TM1's TI process?
else
endif;
Thanks in advance.
The closest you can get to that is to write some code to ensure that you check your variables for valid input. (Non-empty, beyond a certain length, translates to a non-zero numeric value, or what have you.) If you find something invalid, use a standard If block to handle the exception. (Do an ItemSkip or ItemReject, write to a log file, use a default or whatever.) Otherwise the only "error handling" that you have is what TI will do for you, which is up to and including tossing out the row as a result of (say) a key error.
