One of those things that you never need to know till it trips you up. The integer representation of a date differs between Excel/Access and SQL. Eg 3 November 2008 in Excel is 39755 but in SQL its 39753.
There are two reasons for this, one is because Excel starts counting on 0 Jan 1900 while SQL starts on 1 Jan 1900. Two is because a very early version of Excel had an error in the calculations for leap years: it mistakenly assumed that 1900 was one, whereas in reality, it
wasn't. They could not fix this in later versions, because that would break compatibility.
Probably a useless fact, but I thought I'd share it anyway as it almost had me sending an accusatory to a user implying imbecility.
Excel dates differ from SQL dates
- Martin Ryan
Re: Excel dates differ from SQL dates
Actually you can't blame Microsloth for that one. The original error was in Lotus 1-2-3, which had a stranglehold on the market at that time. To ensure that Excel worksheets were compatible with Lotus 1-2-3 ones (which of course mattered greatly when MS were trying to get people to migrate), they had to implement the same bug otherwise a whole bunch of date calculations would be screwed up when you opened a Lotus workbook (of which there were many at the time) in Excel.Martin Ryan wrote:One of those things that you never need to know till it trips you up. The integer representation of a date differs between Excel/Access and SQL. Eg 3 November 2008 in Excel is 39755 but in SQL its 39753.
Now of course if you have a workbook which is shared with a Macintosh user who uses the 1904 date system (Tools -> Options -> Calculation), you ALSO have to factor in...
