N and C rules
buoyant
Version: 10.2.0
N and C rules
Post by buoyant »
Hello Everybody,
Am trying to calculate budget variance percentage. It works fine at 'N' level but doesn't at 'C' level.
Pls can you review the following code and help me.
Thanks :D
SKIPCHECK;
['Variance'] = N: ['Actual'] - ['Budget'] ;
['Variance'] = C: ['Actual'] - ['Budget'] ;
['%Variance'] = N: (['Variance'] \ ['Budget']) * 100;
['%Variance'] = C: (['Variance'] \ ['Budget']) * 100;
FEEDERS;
['Budget'] => ['Variance'];
['Actual'] => ['Variance'];
['Budget'] => ['%Variance'];
['Actual'] => ['%Variance'];
ADMIN NOTE: Moved from the useful code tips and tricks forums
Re: Averages for Consolidations
Hello buoyant
Put it on the same line:
['Variance'] = N: ['Actual'] - ['Budget'] ; C: ['Actual'] - ['Budget'] ;
Please post in the correct subforum, not in the "Useful code, tips and tricks" subforum.
Wim
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
buoyant wrote:Hello Everybody,
Thanks :D
SKIPCHECK;
FEEDERS;
Two remarks here:
If the calculation should work at all levels you don't need to specify the N: or C:, so
['%Variance'] = (['Variance'] \ ['Budget']) * 100;
will do.
If you just want to calculate the difference ['Actual'] - ['Budget'] I would advise you to make 'Variance' a consolidated element with components 'Actual' (weight 1) and 'Budget' (weight -1).
The fact that your above rules are not working for the C: part is probably because you need the AllowSeparateNandCRules parameter in your tm1s.cfg file (or rephrase like Wim just mentioned).
Michel
buoyant
Version: 10.2.0
Post by buoyant »
Thanks Wim it works.
Pls let me know what would be the appropriate subforum for this post, as i have another issue with the same topic.
Secondly, why did it work now and not with earlier code.
Thanks Michael it was a great suggestion, i would love to use it in my future designs.
Thanks again for yr help.
You can create your new topic in this general subforum:
http://www.tm1forum.com/viewforum.php?f=3
