Hi Everyone,
I cannot figure out how it is possible that in Transaction log I cannot see records for approx last 30 days for one specific cube while there are all the records for other cubes.
To check this issue I entered data manually through excel template (DBRW) and also entered in Cube Viewer => there are no records in Transaction Log for these inputs.
We do not have tm1s-log.properties file in place (I am not sure if it is required for Transaction Log) but it worked until approx one month ago - I am not aware of any changes which might cause this.
I tried following in testing evironment (data taken from Production):
1. I cleared Log directory - did not help.
2. I changed ServerLogging to T - did not help.
Thank you for any ideas and suggestions.
Stanislav
						Transaction Log - No Records for One Cube
- Steve Vincent
 - Version: 10.2.2 FP1
Re: Transaction Log - No Records for One Cube
right click "cubes" then choose "security assignments". is the column "logging" checked or not?
				sbalaz
 - Version: 9.4MR1
It so easy if you know where to clickSteve Vincent wrote:right click "cubes" then choose "security assignments". is the column "logging" checked or not?
I tried to find some logging property before, but I did in a wrong place (I right clicked the cube => Properties...).
Thanks for help.
Stanislav
