CX with Citrix
Grazer
OLAP Product: Cognos Express PM
Version: Cognos Express 10.2.1
CX with Citrix
Post by Grazer »
Is anyone using Cognos Express with Citrix?
Dave
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: CX with Citrix
Post by rkaif »
Search for 'Citrix' on this forum and you will find many results :)
Cheers!
Rizwan Kaif
Re: CX with Citrix
rkaif wrote:Search for 'Citrix' on this forum and you will find many results :)
Maybe so, but you won't find any that address his question about CX. All the existing posts are about standalone TM1, not CX. That being sais, I can't think of any reason why the client portion of Excelerator (the CX version of TM1) will not run under Citrix, it's basically the same thing as Perspectives. If you are talking about the other client portals into CX, I suppose they would work under Citrix too since all you need is a broswer session to access them.
winsonlee
Version: 9.5
Re: CX with Citrix
Post by winsonlee »
Citrix configuration is asking for "Command LIne" and "Working Directory" for the application to publish.
I entered ""C:\Program Files (x86)\IBM\Cognos Express Clients\Xcelerator Client\jre\bin\javaw.exe" -jar ce_notifier.jar" for the command Line.
What should i be entering for the "Working Directory" ?
nick_leeson
Version: TM1 10
Re: CX with Citrix
Post by nick_leeson »
http://www.ibm.com/developerworks/data/ ... ge375.html
This document might help another alternative is Microsoft Application Virtualization (App-V) .
jameswebber
Version: CE 10.1.1
Re: CX with Citrix
Post by jameswebber »
winsonlee I know what you mean it took me a few minutes to figure this out too.
I set it up last night.
Ignore the Xcelerator shortcut that IBM provides that will never play ball with citrix
On my server 2008 R2 citrix box
Command Line is:
"C:\Program Files (x86)\Microsoft Office\Office14\EXCEL.EXE" "C:\Program Files (x86)\IBM\Cognos Express Clients\Xcelerator Client\bin\tm1p.xla" "\\<mapped Location>\Menu\Main Menu.xls"
(I load excel 2010, xcelerator and my front end in one go)
Working Directory is:
Make sure your server references the one in your citrix farm with xcelerator on is
Hope that helps
