Anyone using Notepad++ for TI ?
I am modifying the TI and using Notepad++, I need to select the right language or define one that can highlight the keywords or so..... anyone can help? thanks
'highlighter' for Turbo Integrator for notepad++
jimmyrodent
- OLAP Product: abc
- Version: 123
- Excel Version: z
Re: 'highlighter' for Turbo Integrator for notepad++
[DELETED]
Gregor Koch
- Version: 9.0 and up
- Excel Version: 2007 and up
Just a starting point to save you some work. The files work with Notepad++ 5.6.8 and the included TM1 functions are up to 9.1. Check the Notepad++ documentation of your version on how to use them and possible formatting changes.
- NPPlusPlusTM1.zip
- (4.15 KiB) Downloaded 1387 times
There is a fully functional commercial TI editor available that does a lot more than just syntax highlighting. (regionalization, comment/uncomment sections, indenting, intelisense, function wizard, variable and object name insertion, debugging, etc.)Midwest wrote:Anyone using Notepad++ for TI ?
http://www.viziersoftware.com/turbo-int ... editor.php (also see post on the commercial section of the forum)
Disclaimer: I'm not associated with the company behind it (but I have been.)
I just created my own, it was easy to do using the built in style editor - it's a brilliant app!
Midwest
- OLAP Product: COG TM1
- Version: 9.4.1
Thanks Gregor Koch.Gregor Koch wrote:Hi
