I have searched through the forum on this topic. Currently, I'm using Windows 7 and the TM1 server is 64-bit.
I'm trying to develop a TI to connect to an Access DB. When I clicked the "Browse" button in the TI next to Data Source Name field, the list did not include the Access data source that I had created in the 32-bit ODBC Administrator panel.
If I try to set up the same Access data source using the 64-bit ODBC Admin panel, I'm only presented with two drivers: SQL Server and SQL Server Native Client 10.0.
Is there a way to get TI to point to the 32-bit ODBC Admin since I can't define the data source in the 64-bit ODBC Admin?
Thanks!
harry
TI in 64-bit TM1 server cannot point to 32-bit ODBC Admin
harrytm1
- Version: Latest version
- Excel Version: 2003 to 2019
Re: TI in 64-bit TM1 server cannot point to 32-bit ODBC Admi
Does this include the thread under the heading "64 Bit ODBC Driver Issues" in the FAQ? It would seem to be quite relevant.harrytm1 wrote:Hi all,
harrytm1
Yes I did before posting. I posted this because that post did not offer a solution.
Harry, that's because there isn't one. MS Access is a 32 bit application and has (as far as I'm aware) no 64 bit driver. There is no direct route to get data directly from Access into a 64 bit TM1 server, but there are any number of common workarounds, some of which are ...harrytm1 wrote:Yes I did before posting. I posted this because that post did not offer a solution.
- migrate the access application to a RDBMS that supports 64 bit ODBC drivers (such as SQL Server)
- if your TM1 application is small use 32 bit TM1 server
- use a 2nd 32 bit TM1 server as a data staging area
- rather than ODBC use flat files
- automated flat files: use a database tool that supports command line (such as querytool) to pass in an SQL query and generate a CSV file (triggered by ExecuteCommand in TI), then pick up the file
The first and last options are generally my preferred approach.
