Rules bahaving differently following upgrade
- Version: 9.1 9.4 9.5
- Excel Version: Excel 2003
We have just upgraded from TM1 V9.1 to 9.5.1. The rules are behaving differently following the upgrade! After investigation - I believe that they are behaving as they should in V9.5.1 but don't understand how they could have produced the desired results in V9.1. The rules will need to be amended in V9.5.1 to provide the same results as we were seeing in V9.1... Has anyone seen anything like this before?
- Martin Ryan
Re: Rules bahaving differently following upgrade
What needs to be amended?
The usual suspect is the .cfg file as a few parameters in there affect how rules work. You may wish to compare the cfg files between your two versions.
