Can anyone provide any feedback or ideas how to do this
TM1 User Audit
pmerrill
- Version: Version 9.1 SP2 - Update 3
- Excel Version: Excel 2010
TM1 User Audit
We're currently running TM1 9.1 SP2 Update 3 and I'm trying to complete an audit of the users we have within the company. What is the easiest way to determine how many registered users we have and when they last logged in. I am hoping there is some function/command one can run on the server to list all the users with their last login date.
Re: TM1 User Audit
Unfortunately not as such. You can write your own application within TM1 to trawl the }ClientProperties cube and store this kind of information. There are also some pre-built 3rd party commercial applications which already have this kind of thing pre-built.pmerrill wrote:We're currently running TM1 9.1 SP2 Update 3 and I'm trying to complete an audit of the users we have within the company. What is the easiest way to determine how many registered users we have and when they last logged in. I am hoping there is some function/command one can run on the server to list all the users with their last login date.
- Martin Ryan
Re: TM1 User Audit
Another option is to trawl through all the logs (maybe import them into an Access database or some such) and query where the Status field in the }ClientProperties cube changes. I've just tried to do this, however, in version 9.4 and 9.5 and it doesn't work - that Status field doesn't seem to get updated anymore. Perhaps I'm misremembering and it never did.
Do a search on the log though for "Status" or "Active" and you might get lucky in your version.
Re: TM1 User Audit
An example of such monitoring, though using Performance Monitor: http://forums.olapforums.com/viewtopic. ... 450&p=7849lotsaram wrote:Unfortunately not as such. You can write your own application within TM1 to trawl the }ClientProperties cube and store this kind of information.pmerrill wrote:We're currently running TM1 9.1 SP2 Update 3 and I'm trying to complete an audit of the users we have within the company. What is the easiest way to determine how many registered users we have and when they last logged in. I am hoping there is some function/command one can run on the server to list all the users with their last login date.
Unfortunately this will only work for future usage, not past usage.
After they broke the functionality early in 9.4 (or was it 9.1? One of the two), they kindly added it back kinda-sorta provided that you set a config parameter. From the 9.4 MR1 Read Me:Martin Ryan wrote:Another option is to trawl through all the logs (maybe import them into an Access database or some such) and query where the Status field in the }ClientProperties cube changes. I've just tried to do this, however, in version 9.4 and 9.5 and it doesn't work - that Status field doesn't seem to get updated anymore. Perhaps I'm misremembering and it never did.
ClientPropertiesSyncInterval Server Parameter
TM1 9.4 MR1 includes a new Tm1s.cfg server configuration parameter, ClientPropertiesSyncInterval.
This parameter lets you define the frequency (in seconds) at which client properties are updated in
the }ClientProperties control cube.
ClientPropertiesSyncInterval is not included as part of a standard the Tm1s.cfg file. You must edit
the Tm1s.cfg file and manually add the parameter.
Steps
1. Open the Tm1s.cgf file in a text editor.
2. Add the ClientPropertiesSyncInterval parameter to the file and set at the desired interval. For
example, to update properties in the }ClientProperties control cube every 300 seconds (five
minutes), add the line ClientPropertiesSyncInterval=300 to the Tm1s.cfg file.
3. Save and then close the Tm1s.cgf file.
ClientPropertiesSyncInterval is a dynamic configuration parameter. It is applied as soon as it
is added to the Tm1s.cfg file; there is no need to restart the TM1 server.
