Is it possible to feed Measures data to a cube that does not have a common dimension?
For example if I have a Payroll Budget cube with dimensions of Dept, Job Code and Earning and I calculate the GL Account and GL Dollars by business rules in the Payroll Budget Measures dimension, can I feed just the GL Account and GL Dollars to a cube that has GL Account as a dimension and GL Dollars as a Measure of a GL Budget Measures dimension?
Or do I have to export the data and populate the GL Budget cube using a TI process?
Thanks for your help,
...Tom
Possible to feed Measures data to a cube with uncommon dim?
tcasey
- Version: 9.5
- Excel Version: Excel 2003 + 2007
Windows XP Professional Version 2002 Service Pack 3
Excel 2003 + 2007
TM1 9.5 64 bit
Excel 2003 + 2007
TM1 9.5 64 bit
- Martin Ryan
Re: Possible to feed Measures data to a cube with uncommon d
Yes, it's quite possible. In your feeders (and rule) you just need to hard code a few references. Or alternatively make use of attributes to map one dimension to another dimension.
There's an example of the syntax for a problem that's somewhat similar to your own in the Wiki: http://wiki.olapforums.com/index.php?title=TM1_Feeders (see the "Intercube feeders" section)
You might also want to have a look at the rule and feeder posts from the FAQ post.
ajain86
- Version: 9.4.1 9.5 9.5.1
- Excel Version: 2003 2007
Tom,
This can definitely be achieved. I have not tested this but saw a similar implementation in an application.
You would create an intermediary cube that would have dimensions from the other 2 cubes:
Dept, Job Code, Earning, GL Account, GL Budget Measures
In the Payroll Budget Cube:
Skipcheck;
Feeders;
['GL Dollars'] => DB('GL Calc',!Dept,!Job Code,!Earning,DB('Payroll Budget',!Dept,!Job Code,!Earning,'GL Account'),'GL Dollars');
In the Intermediary cube (GL Calc):
Skipcheck;
['GL Dollars'] = n: If( DIMNM('GL Account',DIMIX('GL Account',!GL Account)) @= DB('Payroll Budget',!Dept,!Job Code,!Earning,'GL Account'), DB('Payroll Budget',!Dept,!Job Code,!Earning,'GL Dollars'), STET );
Feeders;
['GL Dollars'] => DB('GL Calc',!Dept,!Job Code,!Earning,!GL Account,'GL Dollars');
In the GL Budget Cube:
Skipcheck;
['GL Dollars'] = DB('GL Calc','Dept','Job Code','Earning',!GL Account,'GL Dollars' );
Feeders;
Ankur
Skipcheck;
Feeders;
Skipcheck;
Feeders;
Skipcheck;
Feeders;
Ankur
Ankur Jain
tcasey
- Version: 9.5
Thanks Martin and Ankur for your responses. I will try your suggestions and report back with my results.
...Tom
...Tom
Excel 2003 + 2007
TM1 9.5 64 bit
Excel 2003 + 2007
TM1 9.5 64 bit
