Workflow, Post and Pre TI Process
MaksimSerkin
- Version: 9.5
i can't adding Post and Pre TI processes to task action. How adding this parameter to work?
MaksimSerkin
- Version: 9.5
Re: Workflow, Post or Pre TI Process
and How does it work?(Pre and Post TI)
Re: Workflow, Post and Pre TI Process
Hello, colleagues!
Does anybody know how to create Post and Pre TIs?
For me it's important to make cubes read-only for the user after Submit, but I cant find any info about how to create and use Post_TI.
Thanks!
Thanks!
I don't think you'll get very much here. TM1 Workflow was never really a functional product, more a piece of demoware glitz. In particular, it didn't actually do anything as far as locking submissions
9.5 has introduced the Contributor component, with ideas lifted from Cognos Planning. From my limited tests this actually works. It's quite new and will need tuning and enhancing, but since it does something, and Workflow doesn't, it's clearly a step in the right direction.
I thought Workflow is more flexible than Contributor e.List-rights.
I worked with Planning for 3 years (from 7.3 to 8.4.1) and know how good Planning Contributor is..
TM1 Contributor needs much enhancing and some of our clients think they are not ready for it now.
But Workflow with its bad sides has some good features.
And the main thing is to find how to lock data after submit.....
