With exporting through the TM1 Web...is there any issues or restriction when the Excel Websheet you created contains 4 cubes? Since when I don't pic any dimension as title, a window opens & close. But when I pick 1 dimension as the title, it said I reach maximum number of sheet. When its only 3 sheets.
What are the configurations that I need to look into for this feature to work properly? When I access TM1 Web through other PC, I get an Operation Failed. So is there anything blocking this feature from working in other PC in the same network?
TM1 Web's Export Slice, Snapshot & PDF
- Excel Version: 2003
- Version: 9.4
- Excel Version: 2002
Re: TM1 Web's Export Slice, Snapshot & PDF
See if this helps you:
1. Make sure that only one Brower (Internet explorer) is open.
2. On the Browser, Go to Tools -->Internet Options
3. Go to Security Tab -->Trusted Sites -->Click on Sites
4. Clear the check box below (Require Server Verification), Type http://servername/ --> Click Add button.
5. Click Close
6. Click on Custom Level
7. Scroll down and Go to Downloads
8. Select Enable for “Automatic Prompting for file downloadsâ€
9. OK
10. OK
11. Close the browser and reopen a new Browser
After doing all this, some times your browser may block the popup when you are slicing/snapshot to Excel. If this happens, you can click Allow popup from this site.
5. Click Close
9. OK
10. OK
