TM1 Web's Export Slice, Snapshot & PDF
appleglaze28
Post by appleglaze28 »
With exporting through the TM1 Web...is there any issues or restriction when the Excel Websheet you created contains 4 cubes? Since when I don't pic any dimension as title, a window opens & close. But when I pick 1 dimension as the title, it said I reach maximum number of sheet. When its only 3 sheets.
What are the configurations that I need to look into for this feature to work properly? When I access TM1 Web through other PC, I get an Operation Failed. So is there anything blocking this feature from working in other PC in the same network?
tosravan
Version: 9.4
Excel Version: 2002
Re: TM1 Web's Export Slice, Snapshot & PDF
Post by tosravan »
See if this helps you:
1. Make sure that only one Brower (Internet explorer) is open.
2. On the Browser, Go to Tools -->Internet Options
3. Go to Security Tab -->Trusted Sites -->Click on Sites
4. Clear the check box below (Require Server Verification), Type http://servername/ --> Click Add button.
5. Click Close
6. Click on Custom Level
7. Scroll down and Go to Downloads
8. Select Enable for “Automatic Prompting for file downloads”
9. OK
10. OK
11. Close the browser and reopen a new Browser
After doing all this, some times your browser may block the popup when you are slicing/snapshot to Excel. If this happens, you can click Allow popup from this site.
