Just thought I'd mention Daptech's new product (Daptech Facet) which is currently in Beta mode. Within a month we will also likely be releasing our new OLAP server also. Daptech Facet is free to use.
Daptech Facet is a free web server upon which you can make TM1 and Palo web applications effectively and easily, using simple functions, like that used in the TM1 Excel-addin (dimix, dimnm, elpar, etc).
The intended administrator/developer is a typical TM1/Palo Administrator. In fact anyone who can write a TM1 TI process or modify TM1 cube rules can easily use this system to produce Custom Web Reports, Workflow Systems, Process Executors with Success Checks, Report Bursters and even TM1 Top Monitors using the simple built-in functions. No more tricky API’s.
As the resulting front-end of the system is a web site, the intended end-user is anyone who can google.
The best part of these (TM1abled, PALOable) web sites, is that any solution that has been made can be published to the Daptech Application Portal for anyone else to download and use (If the developer decides to).
Check out our website now: http://www.daptech.com.au/
Daptech Facet Documentation: http://help.daptech.com.au/
Daptech Forums: http://forum.daptech.com.au/
The Application Portal: http://www.daptech.com.au/appportal.lua
Please also note that the Daptech website is running on Daptech Facet.
As this is a Beta version we expect there may still be a few internal bugs. Please test locally or on a development server before using in production.
Here are some sample images from a TM1 System Documentor made using Facet: (this system can be downloaded from our Application Portal and can be completely customized)
Please excuse the spelling mistakes.
TM1 is a registered trademark of IBM Cognos. Palo is a registered trademark of Jedox. Daptech is in no way related or associated with IBM, Cognos or Jedox.
