Weird space issue in rules
Just wanted to put this out there as I've just had a problem that's taken me a while to track and caused a little bit of head scratching.
I was refering to a hardcoded element in rules in DB statement, but the DB statement would not make the link to the cube.
I copied the reference in the rule and the element from the dimension side by side in Excel and visually they were identical.
The one from the rule however produced a key error, where as the one from the subset did not.
It's only when I compared the reference on a character by character basis that I discovered one of the spaces in the bad name from the rule was ASCII code 160 rather than the normal 32. I don't have the first clue how this happened but just in case anyone else hits it.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Re: Weird space issue in rules
Post by Michel Zijlema »
Hi Steve,
I recently ran into the same thing when the Trim function failed to remove two preceeding 'space' characters from a field in a statistics file pulled from a website. Also here the space appeared to be character 160 instead of 32.
Michel
John Hammond
Version: TM1 Server 11.8.003
Excel Version: 365 and 2016
Post by John Hammond »
I have had the exact same problem: This seems to occur when you cut and paste between excel and SQL server.
Another problem of non obvious lookalikes is the dash and the em-dash which has given me hours of fun!
Steve Rowe wrote:Just wanted to put this out there as I've just had a problem that's taken me a while to track and caused a little bit of head scratching.
Ah, the dreaded non-breaking space, usually picked up from copying a web page. It's caused me grief in VBA/Excel application programming in the past as well, particularly for apps intended to manipulate data within a worksheet. But I agree that I've never seen it raise its head in a rules statement before!
