Help on feeder please...
Christian
Version: 9.4
Post by Christian »
Hi, all,
Happy Friday.
TM1 9.5
I keep getting an invalid string expression error on a feeder I'm trying to write. I have a G&A Input cube, and a G&A Allocation cube. I have a rule that brings in the values from the G&A Input cube into the G&A Allocation cube where the expenses are...well, allocated. :) I use an attribute in the G&A allocation cube to match the account descriptions in the G&A Input cube. This is a sampling of accounts in the feeder below, but all in all, I have about 70 accounts so I don't really want to write rules for each account to be fed, so I attempted this:
G&A Input Cube
Skipcheck;
feeders;
[{'701000 - Bank Service Charges','703000 - Closing Cost Expense','704100 - Delivery','704200 - Postage-Non ops','705000 - Employee hiring','706000 - General Insurance','707000 - Gifts','708000 - Leased Equipment Expense','709000 - Licenses & Permits','709310 - Association Fees','710010 - Office Supplies','712000 - Office Telephone'} ] =>
DB('G&A Expense Calc', !Version, !Department, !Country, !Month, !Portfolio, ATTRS('G&A Expense Calc', !G&A Expense Calc, 'Input');
The error says: Syntax Error on or before !Portfolio, ATTRS(' :Invalid string expression.
Any ideas?
Thanks a lot,
Christian
John Hammond
Version: TM1 Server 11.8.003
Excel Version: 365 and 2016
Re: Help on feeder please...
Post by John Hammond »
You're missing a closing bracket before the semicolon I think.
Christian
Version: 9.4
Post by Christian »
Hmm..I tried that John and it's still not working.
I even tried to do a simple one to one feeder and I'm getting the same error message.
[{'701000 - Bank Service Charges']=> DB('G&A Allocations', !Version, !Department, !Country, !Month, !Portfolio, ‘Total – 701000 – Bank Service Charges’);
My dimensions are in the same order as my target cube (G&A Allocations) so I don't know what else could be wrong.
ItsPat
Version: 9.4
Post by ItsPat »
On the one you just posted you are definetely missing a } around the area definition.
You have:
Should be:
[{'701000 - Bank Service Charges'}]=> DB('G&A Allocations', !Version, !Department, !Country, !Month, !Portfolio, ‘Total – 701000 – Bank Service Charges’);
Christian
Version: 9.4
Post by Christian »
Thanks Pat...that was a typo, sorry about that. I'm still getting this invalid string error. I don't get it, I wrote several similar feeders yesterday.
kpk
OLAP Product: TM1, CX
Post by kpk »
What are the exact dimension names in your cubes?
Based on your rule the last dimension in your 'G&A Input Cube' cube should be 'G&A Expense Calc'.
What is the name of it? Has it a different name, e.g. 'G&A Expense'?
You have to use the dimension names of the source cube in your feeders.
Peter
Best Regards,
Peter
Christian
Version: 9.4
Post by Christian »
Sorry for the confusion. The dimension name is 'G&A Expense Calc', not 'G&A Allocations'. I was trying to stick with my description in the first post.
Below are the dimensions and the order they were assigned (I didn't assign the order originally)
G&A Input Cube G&A Expense Calc Cube
Version Version
Country Department
Department Country
Month Month
Portfolio TBD Portfolio
G&A Expense Input G&A Expense Calc
Revised feeder that is still giving me an invalid string message;
['701000 - Bank Service Charges']=> DB('G&A Expense Calc', !Version, !Department, !Country, !Month, !Portfolio, ‘Total – 701000 – Bank Service Charges’);
kpk
Post by kpk »
I can see 3 possible mistakes in your original rule:
1. Missing ) at the end of your rule.
2. You have to use dimension name of your source cube as variable in the ATTRS function: !G&A Expense Input
3. What is the dimension in your G&A Input Cube? Portfolio or Portfolio TBD? If Portfolio TBD then you have to use that.
Based on the dimension names the target area of your original rule should be
instead of
DB('G&A Expense Calc', !Version, !Department, !Country, !Month, !Portfolio TBD, ATTRS('G&A Expense Calc', !G&A Expense Input, 'Input'));
Peter
Best Regards,
Peter
Christian
Version: 9.4
Post by Christian »
Peter...you did it!!!!
Thank you so much!
