Applications folders
Ajay
Version: 10.2.0, PA 2.0.9
Post by Ajay »
Does anyone know if it is posible to add a non-Excel derivative file into the Applications folders ?
I want to simply drop a pdf training manual there so that my users can get to it easily, but it seems that the only external files I can add, are .xls, .rux or .xdi
Any help greatly appreciated
Ajay
Martin Ryan
Re: Applications folders
Post by Martin Ryan »
Depends on your version I think. Early versions could only have Excel, but later versions can have Word docs, PDFs, and I think pretty much anything.
Ajay wrote: Does anyone know if it is posible to add a non-Excel derivative file into the Applications folders ?
Unfortunately Martin's correct; the ability to add non-Excel documents came in in version 9.1. It's mentioned in the 9.1 release notes. (is_document_1492_Applix91WhatsNew.pdf, page 11.) Since you're on 9.0, you're out of luck.
Martin Ryan wrote:Depends on your version I think. Early versions could only have Excel, but later versions can have Word docs, PDFs, and I think pretty much anything.
Except the ability to hyperlink to them from inside a web sheet. :x :evil:
(Cool new avatar, by the way...)
kpk
OLAP Product: TM1, CX
Post by kpk »
"Except the ability to hyperlink to them from inside a web sheet."
Or...
I inserted the manuals into Excel as an object at one of our client in 9.0.
It was not the most beautiful solution but worked.
From 9.1 you can upload anything.
Peter
Best Regards,
Peter
Ajay
Post by Ajay »
Thanks fellas
We're moving onto 9.5 in a couple of months so I shall hold tight until then
Thanks for your help
Ajay
kpk wrote:"Except the ability to hyperlink to them from inside a web sheet."
Or...
Peter
On a 9.0 SP3 system, I also made a documentation in Excel. With screenshots and the like. It worked but can't say it's an elegant solution ;-)
Wim
