TM1 9.4.1 FP2 server may crash if cube is deleted
harrytm1
Version: Latest version
Excel Version: 2003 to 2019
Post by harrytm1 »
I found the following "Flash Alert" at IBM site while I was looking for a solution to a weird problem on my server even since we installed 9.4.1. FP2.
Flash (Alert)
Abstract
A performance optimization put into TM1 9.4.1 FP2 creates the possibility of a server crash after deleting any cubes on the server.
Content
It is possible in the short term to set a configuration parameter in the tm1s.cfg that turns off the new behavior and would thus avoid this potential crash.
IBM Cognos support recommends anyone running 9.4.1 FP2 turn it off until a fix can be provided. It does require restarting the server after making the change.
Parameter to put in the tm1s.cfg:
InvalidateRuleDependenciesOnDataChange=T
or
InvalidateRuleDependenciesOnDataChange=True
Then restart the server.
The problem is this: in a cube view, if we try to stack more than 2 dimensions as row dimensions, and the data to be viewed is to be calculated, then the action will crash the server. TM1 is running as a service.
I tested on my local which has not been applied with any Fix Pack, and this works fine. I did not apply FP2 on my local due to the issue with TM1 client on FP2 with server on FP2. This feature, being a bread-and-buttter function of TM1, should not have failed so spectacularly.
Anyway, I was quite happy to have found this IBM post and immediately tested it out. Result: FAIL.
I'm rolling back to Fix Pack 1 on my server now and hope this problem does not exist. But I hope that FP1 allows TM1 Web to display validation lists in Websheets, or else I have to redesign a whole bunch of worksheets! Wish me luck... :(
harrytm1
Re: TM1 9.4.1 FP2 server may crash if cube is deleted
Post by harrytm1 »
Forgot to add, the error message after triggering the problematic cube view is:
(SystemServerConnectionInvalid) : Server connection error
It does not matter whether you are using TM1 Client with or without FP2. As long as the server is on FP2, this is it.
Version: PA 2.0.7
Post by jim wood »
We have had this issue in 9.1.3 as well.
Version: PA 2.0.7
Post by jim wood »
Is anybody out there using 9.1.4 FP2 on Solaris 64-bit?
