Hey Everyone,
We are using a SUBNM formula in a cell in PAfE. When Excel is set to Manual Calculation mode, selecting an element from the SUBNM dropdown or the subset editor results in the cell displaying RECALC instead of the selected element's name.
This issue only occurs when the calculation mode is set to Manual.
Is there a way to calculate only the selected cell after the element is chosen?
We tried using Selection.Calculate in a macro, but it triggers before the element is selected.
Supriya
Automatic Recalc
- WilliamSmith
- OLAP Product: TM1 / PA / PAx / PAW
- Version: TM1 11
- Excel Version: 365
Re: Automatic Recalc
Hi there,
If you have Planning Analytics for Excel installed, and you are logged into PAW etc. you can trigger branching recalculation by calling the .Dirty() method on a range of cells.
Here is the VBA documentation: https://learn.microsoft.com/en-us/offic ... ange.dirty
This will not work if the application is set to manual calculation mode, so in VBA, below is the workarounds I use...
To recalculate a specific range:
To recalculate a worksheet:
Sub ReCalcRng(rng As Range)
calc = Application.Calculation
Application.EnableEvents = False
Application.Calculation = xlCalculationAutomatic
Application.EnableEvents = True
rng.Dirty
Application.Calculation = calc
End Sub
Sub ReCalcWS(Optional ws)
If IsMissing(ws) Then
Set ws = ActiveSheet
End If
ws.Cells.Dirty
End Sub
