Advanced rule editor crashes
wang_chris
Post by wang_chris »
Under instruction of GPT, I cleaned up and reinstalled .Net 3.5, and finally load up Advanced Rule Editor in my architect.
But when I click the buttons such as "Check Syntax", "Insert Cube reference", "Brackets", Advanced Rule Editor crashes again. if I select same functions from menu, a popup message window shows below Exception messages.
************** Exception Text **************
System.AccessViolationException: Attempted to read or write protected memory. This usually indicates that other memory is corrupt.
在 Applix.Controls.Tm1ApiDef.TM1ObjectListHandleByNameGet(Int32 hPool, Int32 hServer, Int32 hProp, Int32 sClientName)
在 Applix.Controls.Tm1ApiDef.GetDims(String cubeName, Int32 hUser, Int32 hServer)
在 Applix.Controls.CubeRefForm..ctor(Int32 hUser, Int32 hServer, String curCube, String serverName, Boolean canSelectCubes, String fcnLabel)
在 Applix.Controls.TM1RuleEdit.Insert_CubeRef()
在 Applix.Controls.TM1RuleEdit.menuValidate_Click(Object sender, EventArgs e)
在 Syncfusion.Windows.Forms.Tools.XPMenus.BarItem.OnItemClicked(EventArgs args)
在 Syncfusion.Windows.Forms.Tools.XPMenus.BarItem.PerformClick()
在 Syncfusion.Windows.Forms.Tools.XPMenus.MenuGrid.HidePopup(PopupCloseType popupCloseType)
在 Syncfusion.Windows.Forms.Tools.XPMenus.MenuGrid.ProcessItemClick(BarItem item)
在 Syncfusion.Windows.Forms.Tools.XPMenus.MenuGrid.OnMouseUp(MouseEventArgs e)
在 System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
在 System.Windows.Forms.Control.WndProc(Message& m)
在 Syncfusion.Windows.Forms.ScrollControl.WmMouseUp(Message& msg)
在 Syncfusion.Windows.Forms.ScrollControl.WndProc(Message& msg)
在 Syncfusion.Windows.Forms.Grid.GridControlBase.WndProc(Message& msg)
在 Syncfusion.Windows.Forms.Tools.XPMenus.MenuGrid.WndProc(Message& m)
在 System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
在 System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** load ProgramSets **************
mscorlib
ProgramSet Version: 2.0.0.0
Win32 Version: 2.0.50727.9179 (WinRelRS6.050727-9100)
Base Code: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
TM1RuleEditor
ProgramSet Version: 9.5.0.57616
Win32 Version: 9.5.00000.57616
Base Code: file:///D:/ibm/cognos/tm1_64/bin64/TM1RuleEditor.DLL
Win32 Version: 2.0.50727.9149 (WinRelRS6.050727-9100)
Base Code: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.9176 (WinRelRS6.050727-9100)
Base Code: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Base Code: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Syncfusion.Shared.Base
ProgramSet Version: 5.102.1.47
Win32 Version: 5.102.1.47
Base Code: file:///D:/ibm/cognos/tm1_64/bin64/Syncfusion.Shared.Base.DLL
System.Xml
Base Code: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Syncfusion.Edit.Windows
Base Code: file:///D:/ibm/cognos/tm1_64/bin64/Syncfusion.Edit.Windows.DLL
mscorlib.resources
Syncfusion.Tools.Windows
Base Code: file:///D:/ibm/cognos/tm1_64/bin64/Syncfusion.Tools.Windows.DLL
System.Design
Base Code: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Configuration
Win32 Version: 2.0.50727.9153 (WinRelRS6.050727-9100)
Base Code: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Syncfusion.Core
Base Code: file:///D:/ibm/cognos/tm1_64/bin64/Syncfusion.Core.DLL
Accessibility
Base Code: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
log4net
ProgramSet Version: 1.2.10.0
Win32 Version: 1.2.10.0
Base Code: file:///D:/ibm/cognos/tm1_64/bin64/log4net.DLL
Syncfusion.Grid.Windows
Base Code: file:///D:/ibm/cognos/tm1_64/bin64/Syncfusion.Grid.Windows.DLL
System.Data
Base Code: file:///C:/WINDOWS/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Windows.Forms.resources
Base Code: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_zh-CHS_b77a5c561934e089/System.Windows.Forms.resources.dll
Basic information of my environment:
- Windows: Win 10 Professional 64 Bit.
- .Net Framework: both 3.5 and 4.8 are installed. uses below commands to clean and reinstall
After installing .NET 3.5 (including 2.0 and 3.0) in "Turn Windows Features on or off", use below commands to clear and reinstall the package again. Otherwise, loading the window of the advanced rule editor will trigger a crash.
>DISM /Online /Disable-Feature /FeatureName:NetFx3
>DISM /Online /Enable-Feature /FeatureName:NetFx3 /All
- TM1: PA 2.0.6 (TM1 11.4)
- Architect: bin64\tm1a.exe
- TM1 server can be started and stop normally.
How can I fix the problem?
Chris
Re: Advanced rule editor crashes
You don't.
You are running on 11.x
Just use Arc and stop wasting your time.
wang_chris
Where can I download Arc training material?
